Ceramacoat turbos?
Ceramacoat turbos?
Hi guys,
I have the cold side K16 billets from Sam. I havent installed them yet due to the oil lines being an issue as I have to heat them up to remove them. I did get the billet check valves to replace the stock units when I do remove them.
So is ceramacoat worth the $150 a turbo to do the hot side inside and out by a reputable turbo shop in my hometown?
Pros and cons?
Pros and cons?
I hear ya Sam! I am really concerned about the oil lines getting screwed up. How hard are those to replace? Can you splice into them with aircraft quality SS? Thanks for the Ceramacoat comments BTW.....
I know you guys said to super heat them. When I attempted to gently without heating the line twisted with the flange nut. Seeems if they did get damaged that tying into them would work as long as the overall distance of the line wasnt increased.
Thoughts?
Thoughts?
Hmm
There definitely tricky but it shouldn't be that bad. Give me a call I'll help you through it
I had zero clearenced k04/k16's on my b5 s4 from buhen engineering. They were called buhen bombs and yes they exploded.
Jul 29, 2019 11:13 AM
johnny.dangerous
Aug 21, 2015 10:48 AM
PelicanParts.com
Aug 20, 2015 02:57 PM
