pss9 noises
Old Nov 9, 2005 | 10:49 AM
M3CAB's Avatar
M3CAB has a spectacular aura aboutM3CAB has a spectacular aura aboutM3CAB has a spectacular aura about
pss9 noises
Well, after having my PSS9's installed about a month ago at Tischer auto Park, I knew to expect some noises. Now whenever I drive my car, I hear creaking, and some kind of clanking noises from mostly the front end. I expected to hear creaks from the springs binding when I go into my driveway, but now it is just all kinds of noises even driving straight and hitting small bumps. I feel like something is loose. Should I be concerned or is this normal. Car actually drives great...but is noisy as hell.
Old Nov 9, 2005 | 10:59 AM
20C4S's Avatar
double check the swaybars & drop links.
Old Nov 9, 2005 | 11:05 AM
Cody_1's Avatar
Senior Member
Cody_1 is infamous around these parts
Yep - I'm getting similar noises from my PSS-9's, although I wouldn't call mine "noisy as hell". I had the dealership check it out and they couldn't find anything. Perhaps just the nature of the beast?
- Rich
Old Nov 9, 2005 | 11:12 AM
BartN (TX)'s Avatar
BartN (TX) has a spectacular aura aboutBartN (TX) has a spectacular aura about
Unfortunately I have the same noises as well. It almost sounds as if it's coming from under the dash near the firewall. I jacked the car up and tightened everything one more time including the sway bar and drop-links but it didn't help.
Old Nov 9, 2005 | 11:29 AM
wross996TT's Avatar
I only get creaks when I'm going slow and cranking the wheel.
Old Nov 9, 2005 | 04:16 PM
last911's Avatar
last911 has a spectacular aura aboutlast911 has a spectacular aura about
Are you sure you.........
installed the upper thrust washers on the front struts? The Bilstein instructions are very vague about which OEM parts you are to use in the installation. The shop that installed mine didn't bother to install the thrust washers. I would get the mentioned binding and pop sound at low speeds while slowly turning. Installed the thrust washers, and presto.....quite as stock!
Cheers,
Old Nov 9, 2005 | 04:29 PM
M3CAB's Avatar
Thanks, I never asked if they installed them, since the dealership did the actual install. I will call my mechanic tomorrow and ask. He did tell me that some parts did get transferred from the stock suspension to new, but not sure about the thrust washers. Just curious on what they look like and approximate size since I am going to call tomorrow. Thanks again.
Old Nov 9, 2005 | 05:23 PM
ttgangsta's Avatar
ttgangsta has a spectacular aura aboutttgangsta has a spectacular aura aboutttgangsta has a spectacular aura about
Mine don't make any noise at all????
Old Nov 9, 2005 | 08:04 PM
Zippy's Avatar
Re: Are you sure you.........
Cheers,
Good information. I think the dealer missed the front right when mine was installed.
Old Nov 10, 2005 | 07:30 AM
californian's Avatar
californian is infamous around these parts
I have no experience with these but you may want to look into it.
http://www.tcdesignfab.com/996%20C4S.htm
Old Nov 10, 2005 | 09:10 AM
Beavis's Avatar
Beavis is infamous around these parts
Mine are noise free and no issues. GMG did the install and also installed GT3 bars at the same time. I think the key was their adjustable drop links and their bend to clear the drive shafts. I also had to make sure the length of the connecting bolts was not too long or they would make contact when the wheel was cranked at full lock.
Old Nov 10, 2005 | 03:54 PM
Fabryce@GMGRacing's Avatar
Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !Fabryce@GMGRacing Is a GOD !
The upper spring mount is probably not tightened down enough on the shock shaft thus causing noise.
Old Nov 10, 2005 | 05:36 PM
Ruiner's Avatar
My JICs are quiet.
Old Nov 10, 2005 | 06:43 PM
Garey Cooper's Avatar
Garey Cooper is infamous around these parts
Hmmm, I have the TechArt coil-overs and adjustable sways. Mine only clank on full lock at very low speed into and out of parking lots for instance. But they do make noise. Can one just have the drop links changed?
Old Nov 10, 2005 | 06:46 PM
wross996TT's Avatar
Much depends on the type of PSS9s and the stiffness of the springs used.
