Testing the n75 valve.
Old Jun 22, 2015 | 08:37 PM
VGLNTE1's Avatar
VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !
I was told to add voltage to it to see if it opens. Is it as simple as that? Love a battery charger? Just testing mine to see if it's OK before I just blow 55$ on nothing.
Old Jun 23, 2015 | 09:29 AM
YJosephTT's Avatar
YJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond repute
Why do you think there is something wrong with it?
Old Jun 23, 2015 | 10:21 AM
VGLNTE1's Avatar
Car overcharged and fried the battery. Car wouldn't make any boost
Old Jun 23, 2015 | 12:59 PM
YJosephTT's Avatar
I read that in your other post, sorry to hear that.
Are you thinking the high voltage might have burnt it out also.
Old Jun 23, 2015 | 02:18 PM
VGLNTE1's Avatar
Since I wasn't making any boost, it's a possibility
Old Jun 23, 2015 | 04:28 PM
Jeanmarcboilard's Avatar
Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !
$55 for an N75 valve will be nothing compared to what you'll have to spend if you fried your ECU.
Old Jun 23, 2015 | 04:37 PM
VGLNTE1's Avatar
So....does anyone want to respond about the topic?
Old Jun 23, 2015 | 04:38 PM
VGLNTE1's Avatar
I had no idea captain obvious was a member here!!
Old Jun 23, 2015 | 05:40 PM
N75 valves fail safe (air to wastegates). If you fried your N75 valve it would still be making boost pressure, just not as much as your ECU is commanding. I thought that was obvious.
Old Jun 23, 2015 | 06:07 PM
jpflip's Avatar
If you put 12 volts directly on the valve (only two wires) you should hear a click and if you blow air at the same time through the opening (with your mouth), with power on you should be able to blow air through the valve and with power off you should not be able to blow air into the valve....Simple test....
Old Jun 23, 2015 | 06:22 PM
VGLNTE1's Avatar
Ya...I guess I just need tiny connectors to go to the posts inside the clip
Old Jun 23, 2015 | 06:24 PM
VGLNTE1's Avatar
Exactly...why I want to test it. Obviously......
Old Jun 23, 2015 | 06:25 PM
jpflip's Avatar
Durametric got a function to test this valve and you can clearly hear the click....Of course this tool is on your shopping list!
Old Jun 23, 2015 | 06:34 PM
You said you weren't making any boost. Are you making no boost 0.0 bar or not as much as normal?
Old Jun 23, 2015 | 06:35 PM
VGLNTE1's Avatar
Ha, yes it is. Guess I finally need to throw some money at the old girl.
