Testing the n75 valve.
I had to troubleshoot almost every system in my car over the last 6 months until I finally got to the ECU, which ended up being the problem. I wasn't trying to be a dick, just saying if $55 is all you have to spend you'd be lucky.
I know...but spending needless money never helps. A buddy just had his ecu go out. What was your symptoms?
PSM/ABS fault light on constantly. But my problem was a local tuner messed up my ECU when he tried to tune it by swapping chips instead of loading files through the OBD2 port. I didn't know that's how he tuned until after it was done.
Likely not your issue, lol, but I did a lot of troubleshooting before I tried another ECU and tune. So I will try to be helpful.
I will add, a bad N75 doesn't always mean complete failure, lower then commanded boost-but still 'healthy' pressure can occur as well
Jean-Marc might be onto something here as well...you have had PSM/ABS lights under heavy load/1bar+boost..? wonder if it's another MAF/load/tuning issue here eh Jean-Marc..?
Yeah Rob, it does sound all too familiar.
Except for the drive shaft removal issues the op mentioned in an earlier thread. That seems to be the start of all the problems.
I would get in touch with a few of the well known tuners on here and see if they can shed any light on that and maybe your subsequent problems.
From my experience, some tuners kind of see it as a challenge and enjoy getting these types of issues sorted out.
Maybe start a new thread with the history of the car, mods, tunes, symptoms, and what you've checked.
Again, I'd also replace the MAF, very sensitive sensor and cleaning is a Band-Aid at best...ECU needs to know its incoming air mass to make load calculations
sdg1871
Dec 24, 2015 12:22 PM
proTUNING Freaks
Sep 17, 2015 01:07 PM
