Rattle at idle and low rpm ?
Old Nov 11, 2005 | 09:11 AM
timf's Avatar
timf has much to be proud oftimf has much to be proud oftimf has much to be proud oftimf has much to be proud oftimf has much to be proud oftimf has much to be proud oftimf has much to be proud oftimf has much to be proud oftimf has much to be proud of
Hi Guys,
been a lurker here for way too long with not too many posts, but always check in for ideas / tips on my 911TT.
Now here's something which has been troubling me - I hope it's not a problem and is considered 'normal' for a 911TT.
At idle the engine sounds awful with all sorts of mechanical rattles - I'd like to think it's timing chain chatter, sure is loud though. Once the engine gets above about 1400rpm it largely goes away.
I've also notice a lot of transmission noise up to about 30mph - most noticable when driving thru' tunnel. Again is this to be expected ?
I'm a little wary as the original engine was replaced at 7000miles and this replacement at 7,000 miles while smooth and strong makes all these noises.
FYI the original engine was replaced due to a porus casing.
Thanks Tim
Old Nov 11, 2005 | 10:17 AM
Bruce's Avatar
Member
Bruce Is a GOD !Bruce Is a GOD !Bruce Is a GOD !Bruce Is a GOD !Bruce Is a GOD !Bruce Is a GOD !Bruce Is a GOD !Bruce Is a GOD !Bruce Is a GOD !Bruce Is a GOD !Bruce Is a GOD !
Unfortunately the mechanical noises at idle are normal, some cars are worse than others. It is the intermediate shaft rattling at idle speed. As far as I know there is no fix for this. There should be no transmission noises like you describe. Are you sure it's coming from the tranny?
Old Nov 11, 2005 | 11:39 AM
variable's Avatar
variable is infamous around these parts
Unfortunately the noise at idle and low rpm is normal. The transmission noise I don't know about. I don't have it on my car. Maybe more people will chime in?
Old Nov 11, 2005 | 01:21 PM
russbert's Avatar
russbert is infamous around these parts
Cool
I was told this noise is just the scavenger oil pump on the TT ... is that correct?
Sounds like a loose right tailpipe rattle at idle especially when the car is warm.
Comments?
Old Nov 11, 2005 | 03:27 PM
osu s2k's Avatar
osu s2k is infamous around these parts
when i first got mine i thought it was a heat shield or something, but it makes an aweful racket at idle which slowly improves when warm, my brother says it sounds like a bucket of bolts. I talked to the dealer, they told me its normal and nothing can be done about it, i just ignore it now, crank up the radio.
Dont know about the tranny though.
Old Nov 11, 2005 | 04:43 PM
variable's Avatar
I'm wondering if a louder exhaust might hide the rattle more... anyone want to comment on that?
Old Nov 11, 2005 | 05:29 PM
rico930's Avatar
Junior Member
rico930 is infamous around these parts
yep idle rattle is normal, longitudinal endplay on intermediate shaft. dealers say it is in spec and will not do anything about it, i tried on my '01. Make sure when you go to the dealer you have them document it so it is on record. I tend to mention it whenever i go to the dealer to establish a record history. You never know if something does happen and there is a history they might help you out. I does kind of sound like a loose shield or something.
variable, that was my thinking as well and the Fabspeed exhaust does nicely to drown out noises.
As far as the trans, are you sure its in trans? It sounds funny but i had an AWD car that made a trans problem-like noises and turned out to be the tires !
Old Nov 11, 2005 | 07:09 PM
monsoonmadness's Avatar
monsoonmadness is infamous around these parts
It is normal and some have it more than others.. My first 996TT in 02 was loud as hell with that. My new 05TTS is almost as loud as the 02.. I would bring your car in to get looked at as far as that transmission noise is concerned.
Old Nov 11, 2005 | 07:18 PM
variable's Avatar
That is good to know, thanks.
Old Jan 29, 2014 | 06:20 PM
Porschecab1's Avatar
Porschecab1 is infamous around these parts
Engine noise at low rpm
Has anyone tried Redline 15w 50 syn oil for noise
Old Jan 29, 2014 | 08:10 PM
Its normal...
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Jan 30, 2014 | 10:49 AM
Macster's Avatar
The Turbo engine is a bit rough/ragged when started from cold. I hear mine backfiring some through the exhaust. The engine is being fed extra fuel to be burnt in the converters to warm them up quicker.
Additionally the low valve lift is enaged and this makes for a bit more noise.
If I let the engine idle a while the idle smooths out, the engine quiets down, and the RPMs drop to near normal hot idle speed.
Be sure the oil level is good. Be sure the oil is not too old. These engines can really dump a lot of contaminates in the oil -- courtesy of the turbo charging -- and this dilutes the oil and can make the engine more noisy. Even though I change the oil every 5K miles in my Turbo (and my other Porsche) the engine is noticeably quieter after an oil change even after the fresh oil gets up to temperature.
I would not run some 15w-50 oil. I do not see it a suitable trade off to perhaps get a quieter engine -- though the noise is normal -- at the expense of running a sub-par and unsuitable oil that exposes all the engine to the risk of accelerated wear/tear possibly even damage arising from inadequate lubrication.
Old Jan 30, 2014 | 10:51 AM
HIX's Avatar
HIX
HIX Is a GOD !HIX Is a GOD !HIX Is a GOD !HIX Is a GOD !HIX Is a GOD !HIX Is a GOD !HIX Is a GOD !HIX Is a GOD !HIX Is a GOD !HIX Is a GOD !HIX Is a GOD !
Holy 'raised from the dead' post!!
Paintballzen
Oct 10, 2020 12:22 PM
GSP
Sep 9, 2015 05:31 AM
Saint Ari
Sep 4, 2015 03:30 PM
porsche42
Sep 4, 2015 08:21 AM
AuZZie
Sep 2, 2015 04:26 PM
