Anyone here replaced the alternator/starter/battery cable?
Old Jun 27, 2015 | 02:16 AM
VGLNTE1's Avatar
VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !
Still fighting my voltage jumping at idle. Goes between 11.5-14 and pulses. I've changed the battery and alt and still no fix. I've read it's really common that these cables can go bad. Anyone have these replaced? Do it yourself?
Old Jun 27, 2015 | 06:29 AM
32krazy!'s Avatar
it just so happens i have a motor sitting on stands so i grabbed a few pics for you! looks like its a diy with some patience. it feeds under the oil tank behind the a/c compressor under the oil filter and up to the jump point and alternator. looks like theres some tie wraps holding it along some other harnesses but doesn't look to awful difficult. remove the a/c compressor and lay over the back of the car. this will get you the most access. no need to remove the a/c lines.
heres a few crappy pics
ID:	422857   Click image for larger version
ID:	422858   Click image for larger version
Old Jun 27, 2015 | 06:55 AM
'02996ttx50's Avatar
go get a new bosch and repeat r&r. my 02. ( again sorry )
Old Jun 27, 2015 | 07:12 AM
32krazy!'s Avatar
^ quit lusting after my clutch! you know you want one
Old Jun 27, 2015 | 07:48 AM
sorry steve, it's really your fuel setup i want ha
Old Jun 27, 2015 | 08:50 AM
stevemfr's Avatar
stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !
Before just diving in and replacing the cable: get a voltmeter and measure the voltage at the + connector at the back of the alternator. If the voltage is jumping there, get another new alternator. If not, optimally, you'll work your way down the line and check the voltage at each major connection: starter, battery, fusebox.
And if you'd keep everything in one thread it would be easier to follow...
;-p
Old Jun 27, 2015 | 09:00 AM
VGLNTE1's Avatar
;-p
Ha...yes, I've been all over. Just frustrated. So, if the alternator is buried, how do I test it with load?.I have to have everything taken apart.
I need to find a meter that has long enough cables to reach from the starter to battery. Where on earth do I find that?
Old Jun 27, 2015 | 09:02 AM
VGLNTE1's Avatar
Sweet! Thanks. I need to check the voltage but ripping these out looks like a job where I will be throwing wrenches across the room.
Old Jun 27, 2015 | 09:14 AM
rmc1148's Avatar
Do not start replacing parts before as noted above doing some trouble shooting.
Old Jun 27, 2015 | 09:37 AM
VGLNTE1's Avatar
Yup. I am looking for a someone that has a voltage meter with good long lines.
I don't even know what setting to put the volt meter on. I'm so lost when it comes to electrical
Old Jun 27, 2015 | 10:04 AM
rmc1148's Avatar
You could also run a temp ground.
Old Jun 27, 2015 | 10:47 AM
993GT's Avatar
993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !
+1, and check your ground cable engine to passengers-side frame rail...common for these to be loose or have a 'dirty' connection, release, clean and retighten..
Old Jun 27, 2015 | 11:17 AM
VGLNTE1's Avatar
Looked at the ground and it's clean and tight. Haven't cleaned it yet. Put a volt meter on the battery. Reads 12.8. Started the car and put a load on it. Lights, ac, ect. And fluctuates between 13.2 and 13.8 at idle. But I can see the lights dim a hair every few seconds.
Old Jun 27, 2015 | 11:29 AM
BLKMGK's Avatar
Digital meter? If so it may be moving even more and not fast enough to see it. Analog meter with a needle may show more swing or maybe even try setting it for AC? Sure sounds like the alternator. If you get another maybe test at the store before leaving if they can do it
Old Jun 27, 2015 | 12:02 PM
993GT's Avatar
connect a 'hot' wire to the alternator trigger terminal and see if that helps
