Reverse Lights
Old Jul 29, 2015 | 10:12 PM
Infamouz's Avatar
Infamouz is infamous around these parts
Reverse Lights
With the recent acquisition of a 2001 996 Turbo in auto (tip), I've stumbled onto a problem. I've read up on this a bit and tried to figure it out, but I don't believe I've come across an individual mentioning the same symptom.
When I put the car into reverse, the reverse bulbs both turn on for half a second, then turn back off, and stay off for the remainder of the car being in reverse.
Is this curable by replacing this reverse sensor that I've read about that is located on the transmission, or under the gear lever on tip models?
Old Aug 2, 2015 | 07:36 PM
Infamouz's Avatar
No thoughts with all these views?...
Old Aug 2, 2015 | 11:22 PM
rmc1148's Avatar
Check wiring for loose connections worn areas, more than likely reverse sensor.
EMC2
Cayenne 955/957
Sep 7, 2015 05:20 PM
GSR Autosport
Aug 26, 2015 05:20 PM
nreddy
BMW //M
Aug 26, 2015 11:42 AM
ECS Tuning - BMW
Aug 21, 2015 02:00 PM
