Warm start/RPM issue
Old Aug 29, 2015 | 07:46 PM
ritchrwi's Avatar
ritchrwi is infamous around these parts
I have a 2003 996tt, which has developed a warm start issue. When the car is warm it starts fine (first crank) but after about 10 seconds the RPMs go to 400 then sometimes the car cuts off. If i gas it for a bit then its good to go.
Need some help?
1. I changed MAF sensor,
2. Put new gas in car
3. I have read could be check valve on fuel pump?
4. Starts great cold and hot, rpm stabalize normal
5. Plugs have not been changed after flash
6. coils have not been changed after flash
I have EPL tune
Evoms intake
Fabspeed exhaust
Old Aug 29, 2015 | 07:52 PM
johnny.dangerous's Avatar
johnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud of
Any codes? doubt its check valve as the car starts so it shows fuel pressure is there.
Old Aug 29, 2015 | 07:54 PM
ritchrwi's Avatar
The car has no codes, runs like a champ once it gets going.
Old Aug 29, 2015 | 07:57 PM
What happens if your tuner flashes the stock map back on? Does it still do it?
Old Aug 29, 2015 | 08:22 PM
ritchrwi's Avatar
I have not contact tuner about issue.
I have not tried to put stock tune back
On car.
Old Aug 29, 2015 | 08:27 PM
If its changed since the tune and it bothers you its pretty simple to do and may save you chasing your tail !!!! That will eliminate the tune, are the lambas quite new? Could be the post cat ones thinking the mixture is wrong or a temp sensor not detecting the car is already war.
adnanm3
Nov 22, 2023 02:43 AM
PV=nRT.
Sep 9, 2022 06:06 PM
Rguy
Apr 12, 2020 11:11 PM
proTUNING Freaks
Sep 15, 2015 07:28 AM
oo7
Sep 10, 2015 08:08 AM
