Upgraded aero and brakes for 996tt
#106
We know sometimes even the producers are wrong, guess you know better than anyone LOL, I have checked Pirelli's site, they say 12.5 ideal size for 325/660-18... another example would be the 335 R888 they say 12-12.5 to be ideal... idk why..
Now another example, the 315/30/20 R888 were specifically designed for GTRs to fit even OEM rims, oems are 10.5 only... on their website they say will fit 10.5-11-11.5... clearly the 10.5 are too small... gt-r guys are even running 335 MPSS (seems mpss are narrow -almost same width as 315 R888) on 10.5 wheels.
I run the new version R888R on 10.5size rim and guess a 11.5 would be ideal. fronts are 285 on 10 and they look fine
#107
#108
I have decided to go on 997.2 gt3 brakes route as you recommended, but consulting your (really nice&helpful) list bellow I have found 6 caliper codes instead of 4 and have seen for fronts you recommended 2 models
997GT3.2 PCCB brake calipers: 997 351 431 92 and 997 351 432 92
But also
Calipers: 997 351 427 32 and 997 351 428 32
Guess the second are from 991 turbo ...
I would guess that the first ones are the correct buy for us, isn’t it ? Also will buy pads for gt3 997.2, not sure they are the same with 997 turbo . Thanks
But also
#109
But also
But also
Just sent you a PM regarding the suspension. Regarding the 380 calipers, this is the part number for the front 7GT3 PCCB versions:
DO NOT use the 427.32 and 428.32 versions. Those are the 997TT PCCB versions which have larger pistons and do not have the zircon insulators. These are not rebuildable.
The 997GT3 pads are the same size pads as the 997 turbo version but they are a different compound.
Rear caliper part number are 997 352 425 98 and 997 352 426 98
#110
Hey Fadi,
#111
Hey guys, this is what I am going to do, hope is ok..
Girodisc 380mm front and keep the rear Giros 350mm
Pads wil be Performance Friction - PFB08 fronts and PFC08 rears, gt3 size
FRONT
Caliper adapters: 997 351 505 02
Adapter bolts: 999 073 313 09
997GT2 oil scavenge / vacuum pump 997.107.022.72
997GT2 vacuum line 997.105.116.73
997GT3 brake master cylinder - 99735591030 ?????? not sure if this is the right PN ????
REAR
997.2 PCCB rear Calipers: 997 352 425 98 and 997 352 426 98
Rear Supports: 997 355 503 10 and 997 355 504 10
Rear Brake lines: 996 355 585 11 and 996 355 586 11
Rear Caliper bolts: 999 067 040 01
Not sure if will need other adapters pt good to know we have options.
And one other question, does anybody have the measurements bellow just to know and make sure once and for all if one rim will fit and clear the 380mm+gt3 calipers
I am running oem 996tt uprights, etc.. I am looking for measurements like the ones bellow, I am trying to order my rims, but might need to wait on calipers delivery first. thanks
FRONT
REAR
#113
aero
any body uses this design of rear wing? i am going to use some flares and getting car 1inch wider each side, 160cm/63" wing should still look ok I guess, or should I do even wider wing?
Also this German supplier can do only RSR type wing, not Cup... (pics bellow) Idk what that means in terms of aero, but here are some pics, should I go with the rsr instead of cup ?
In front might do Joe Toth splitter and canards, hope the splitter will fit as front bumper is going to be wider too
#114
#116
The stock decklid doesnt have an inlet IIRC (been a long time since I looked at one). Im wondering if that is actually necessary.
#117
#119
[url=https://flic.kr/p/KTkSRb]
I have both a Getty decklid (pictured below) and an OEM GT2 decklid/wing. Both have air intakes in the vertical uprights which are exposed to ram air feeding the OEM air box with positive pressure air via an inlet on the passenger side. Works well. Just make sure you have a tight seal between the lid and the air box. To get a better seal I transferred the seal to the air box and use a flat CF plate on the decklid. None of this really applies in your case as you have fender well intakes and the air inlets in the decklid are useless.
[url=https://flic.kr/p/LgJD8C]
#120
wide body
Yes this is the route I am going to do, I already run a fully functional gt2 in front and adding splitter, canards etc.
Seems to me the 62-63" wing is exactly the same size as the body, from a functional and design perspective we should be able to run whatever size we want, but seems more elegant to be the same size ?! In this case I might need a custom size 65" wing (63+1+1)
Front will be wider too, I dont have pics of a turbo/gt2 based setup but looks like this, hoping to be able to fit in front 26.0" tires after doing again the radiator mod and all tricks that I know of, if can get this done, than the tire options is just... huooaaaaaa huge !
