Upgraded aero and brakes for 996tt
#136
Fadi, '02 996 GT3 RS (not the street RS, but successor to GT3R) has about 50 mm flares each side and runs
-wheels 10x18 et 0,5 (2"/8") & 11x18 et 16 (2"/9")
-tires 265/645 & 305/690
Track width is F 1562mm & R 1578 mm. (Base 996 Carrera: 1465 & 1500 mm)
To get wider front track without using low offset you always can play with LCAs and GT3 top mounts. 20 mm shims and top mount at street position (not rotated), pulled fully outboard, will give you about 3.2-3.3 deg camber. And 20 mm more track each side. With 997 LCA's wider (15mm more than 996's) inner section with 996 LCA's outer section and 20 mm shims you're 35 mm wider / side than street car, with streeet car's offset. Then of course you have to figure out how to move top mounts that 15 mm outboard. Which is actually quite easy...
Thrust arms must be adjustable and track rods might be extented to their limit...I've so far tried that 20 mm shimming, but will know about 35 mm within a month.
Last edited by pete95zhn; 12-20-2016 at 07:38 AM. Reason: Clarification of parts to be used
#137
All 4 rims will be 3 piece custom made, as we dont run wider cars from factory can do higher ET and eventually add some spacers or going with lower ETs from the start and having advantages on looks in my opinion and keeping also the oem wheel studs, the only downside will be to calculate the offsets so nothing will rub there, I got my info regarding ETs from John, aka the ultimate guru here imo, and converted his offsets using 10/13 rims to flared fenders 10/13 and 10.5/13 but 10.5 in front seems to make more sense as anyway running 275 or wider front wheels only
like said above this one, going to a wide front lca would probably be best. Helps with scrub radius a lot and will probabaly give you slightly better suspension control up front. That's just my 2 cents.
#138
Been covered before, but wanted to check with you experts. I have some 18" CCWs (9" and 12") made for my 997 NB GT3 and want to use them on my 6TT. Fronts will fit as is and looks like 15-20mm spacer is needed in back. I'd prefer a bit wider then stock turbo twists (without spacers). Does that sound like 20s are the right answer?
#139
#141
Seems we need some answers to a new problem, going to install some fender flares and car should be 4.5cm wider each side in the front and 8cm in the back, after lots of thoughts I would do 10.5 fronts and 13 rears.
10.5 fronts should allow to use 265+ wheels and going up to 295 or so
13 should be enough for any tire on the market
Now the problem seems to be the ETs, as I calculated they seem to go negative
10J fronts ET -5
10.5J fronts ET 0
13J rears ET -25
The looks should be great, but what about performance, are there any downsides to go negative offsets? I know Cups run small positive offsets but they are built wide from the factory.
From what I have read, seems to worry about scrab radius, wear on bearings, knuckles, uprights, and other components (I am fine with that if not a big concern regarding my own safety), might have to read more about suspension settings in general and our cars in particular.
Anybody raced their cars using negative offsets? I see only RWB kits and old school racing cars using those, wondering why ?
10J fronts ET -5
10.5J fronts ET 0
13J rears ET -25
I would push your upper mounts as far outboard as possible. Possibly even have some custom upper mounts that would push the shock even further outboard than what is possible with current hardware. You can also slightly grind out the tub (like I have done) to give you more clearance. Basically you want to do the reverse of what I have done with my set up (see pic below) where I have the shock located as far inboard as possible via motorsport camber plates in order to clear 275s into stock fenders. By going fully outboard compared to where I am you would gain about 3cm in track per side. Running a wheel with a 15mm more aggressive offset than what I'm running would get you 4.5cm greater track per side. That would be a 18x10 et23 (I'm using et 38). Naturally this is just rough math but my gut tells me it's pretty close if you push the shocks as far outboard as described above.
I can't recall what LCAs you are running, but with the 997RSR LCAs you can run the 20mm longer inner bearing and another 15mm of shims to give you 35mm longer LCAs. PMNA makes two version of the 997 inner bearing, the short and the long. I run the short, you'd want the long. Contrary to what you may read, the forged PMNA 997 LCA main body is actually 5mm SHORTER than the stock 996GT3 LCA body but you can easily get that back with the longer inner bearing and shims.
[url=https://flic.kr/p/P8D5B6]
By running such low / negative offsets, you will certainly place a greater load on the hubs/bearing/and upright. How much greater is hard to say, maybe 10-15% greater but thats just a guess. When you combine that with super wide rubber and or slicks, you will definitely add more stress to the components. Personally I would probably stick to the service interval recommendations that you will find in the Cup manual. 40hrs running time is the maximum specified by Porsche on the rear hubs at which point you would also naturally do the bearings. Uprights do not have a time interval but a visual inspection for cracks is required every 30hrs of running time.
[url=https://flic.kr/p/QiTHcs]
One thing to keep in mind when running these low/negative offsets is that you will greatly increase the turning radius of the front wheel/tire assembly, on the order of 40-45mm greater radius. This is naturally require 40-45mm more clearance ahead of the front tire to clear the radiator brackets. This is a huge amount as you will basically need to move the side radiators forward by a similar amount, basically about 50mm forward of stock location. I'm not sure this will be an easy feat. I would take a look at that to make sure that is even possible. As a data point, with a 18x10 ET38 front, I had to move the front radiators forward 10mm. You will need to go another 40-45mm further forward. Have you come up with a game plan to deal with that?
The project looks exciting. Looking forward to the results...
#142
Hey Pete, Lewis and John the great news is you showed me there are solutions that address correctly my future setup, seems we need to do a lot of measurements and try, try, try before finding the real solution.
Will postpone at least the wheels ordering till getting the flares installed and start working from there, of course will still try to push forward the radiators (did already that, but not sure by how much I have managed to do it, I am able to fit 265/35/19 tire for example, not hitting the radiator)
I have RSS suspension arms, so can add large shims, both turbo and gt3(longer) drop links and good coilovers with new top mount to come in the next days (Intrax), so might have a chance, thanks god you are here, seriously without your help I wasnt even thinking that was the way to go, thanks and will keep you up to date
#143
Parts
Just some updates regarding various pats going in this winter
Girodisc 380mm F and 350mm R
PFC brake pads 09/11
Gt3 996 front uprights
Patrick Motorsports trans cooler
CSF Radiators
Plex Tuning Dash Display
Rennline track mats and pedals
LI-Ion 18Ah Battery PowerBloc
The stripped car pic isnt actually mine, but might try it in that configuration for a few times to be honest , but guess will end putting back some of the interior later on
CSF Radiators
#144
CSF Radiators
CSF Radiators
#145
Are you referring to running 997.2 GT3 uprights vs. older uprights with spacers? If so, I'd think that running stub axles with 996 trigger wheels and mounting the 996 ABS sensors is the issue to consider.
Has anyone mounted 997 uprights on a 996 yet? As the late 996 GT3 RS and early 997 GT3 share the same uprights, I can't imagine that it is too much of an issue.
#146
Are you referring to running 997.2 GT3 uprights vs. older uprights with spacers? If so, I'd think that running stub axles with 996 trigger wheels and mounting the 996 ABS sensors is the issue to consider. Has anyone mounted 997 uprights on a 996 yet? As the late 996 GT3 RS and early 997 GT3 share the same uprights, I can't imagine that it is too much of an issue.
#147
#148
Are you going with 6pot front porsche calipers and spacers? Or 997 GT3 setup? Only reason i'm asking is because depending on what you end up doing you may be faced with some customer brake line and ABS wire mounting things to resolve. Nothing major, just keep it in mind.
Going to use the complete brake system from 997 gt3, including brake master pump, brake line,etc. Got the PNs and info from master John
#149
Going to use the complete brake system from 997 gt3, including brake master pump, brake line,etc. Got the PNs and info from master John No, I will be running 996 gt3/rs uprights instead of the original turbo uprights
#150
Here's how 10x18 et37 & 11x18 et5 look like on a narrowbodied RWD, ie I need some flares...
Wheel to spring clearance at front is about 1.8 mm:
Rear:
Rear:
