Whats the fastest you taken her up to?
Old Sep 24, 2015 | 11:43 AM
YJosephTT's Avatar
YJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond repute
whats the fastest you've gotten your 996tt up to?
in mexico or on a closed track of course
I've hit 160 twice, first time was against a Hellcat and he ate me up but I didn't floor it all the way cuz car felt scary.
Second was recent after having my suspension re-aligned and tightened up, car now feels much more stable.
my only suspension mod are H&R springs.
Todd need not apply we already know...
Old Sep 24, 2015 | 12:10 PM
b4stiTTS's Avatar
b4stiTTS has a spectacular aura aboutb4stiTTS has a spectacular aura about
211 on the German Autobahn Unfortunately just on the Speedometer and not GPS verified.
Problem is the Gearbox and revlimiter, oherwise maybe more.
Old Sep 24, 2015 | 12:22 PM
WOODTSTER's Avatar
200 mph in my old Protomotive 700 kit.
On a VBox.
Todd Knighton calculated my top speed with raised rev limiter and 19" tires at
211 mph. (I have since sold the car to another forum member)
It also did 190.743 at the texas mile at 1.4 bar.
Old Sep 24, 2015 | 12:29 PM
TabooPc's Avatar
TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !TabooPc Is a GOD !
This summer I hit 214mph in the Sunvalley Road Rally (In idaho).
There was a 12 mph headwind too. It was extremely scary. It pushed my car all over the road and I even had tire squeal at 200+.
The previous year I did 211.2 redlining in 6th 1/4 mile before the finish.
Heres the video from the previous year, if anyone is interested...
Cheers!
Old Sep 24, 2015 | 02:28 PM
03EvoIII's Avatar
03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute
Taboo - That looks like an awesome time!!!! What's the cost to do that?
160+ mph a couple times so far in the turbo. Somewhere in Kansas and once here in CO.
Old Sep 24, 2015 | 02:29 PM
YJosephTT's Avatar
My Porsche Gt2 Run @ The Sunvalley Road Rally - YouTube
Cheers!
What was going on with your battery voltage looked way down, is that what made your speedometer go haywire?
Old Sep 24, 2015 | 03:17 PM
b4stiTTS's Avatar
TabooPc, with modified gearbox or?
I think also 211 speedometer is max. for the OEM gearbox or?
Old Sep 24, 2015 | 03:58 PM
TabooPc's Avatar
Its $2000 per run, and I usually do two.
The ribbon connector within the gauge was actually just disconnected from the last time I had worked on my gauges. Its unrelated. The speedo doesn't go past 206. The second it hits 206 the car has no idea what speed its moving. Kind of strange.
No same gearbox, but I got 211mph with 7200rpm redline and 315/30/18 rear tires. This year my rev limiter was raised to 7300 and I switched to 305/35/18. Supposedly my redline was 222 with the raised limiter and new tires. I think the headwind and weird traction was what caused me to not make another 6 mph.
This run is also a great tribute to the strength of these engines with proper tuning. This year I ran 1.6 bar on 3073 turbos. I was WOT through all 6 gears at an altitude of 5000 feet. Its all in the tuning and power delivery!
Old Sep 24, 2015 | 04:06 PM
03EvoIII's Avatar
Whoa!!! $2k per run!!!
Got to make it count for sure!
Old Sep 24, 2015 | 04:18 PM
TabooPc's Avatar
But its a charity event. So its tax deductable, and for good cause! The profits go to the Blaine County Drug Coalition to fight against youth drug use.
Old Sep 24, 2015 | 04:19 PM
VGLNTE1's Avatar
VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !
How are some of you going so fast? I bang off the red limiter at 188 in 6th with stock tire sizes and I think the red limit is 7000 or so. I went to my 305/30/19 but haven't seen if that would go any faster, or if the speedo would correct for it.
Old Sep 24, 2015 | 04:24 PM
TabooPc's Avatar
The stock rev limiter is 6800. Depending on tuner its sometimes raised. But it depends. Kevin at UMW (Not my tuner, but I know of this) sometimes even lowers it from stock for those bad drivers that don't like to shift until it starts bouncing in the red.
Stock tire size on the turbo is what 295/30/18? So a 0.75 6th ratio means you should be going exactly 198 mph at 6800... Which sounds like you're pretty far off. If you cant get to 198, its probably becuase you're down on power. I'm not sure if just a tune can get you past 188. Ferrari italias only run about 185 in the rally, and they're 540 hp and lighter than turbos (But my gt2 is 3100lbs).
If you had a 7k rev limiter you would be going 203 at rev limiter.
However, I have no idea how the 4wd system effects this.
Old Sep 24, 2015 | 04:38 PM
03EvoIII's Avatar
^^^FYI Garth @ UC set my rev limiter to 7400!!
I figured it might be for charity....good cause!
Old Sep 24, 2015 | 07:28 PM
VGLNTE1's Avatar
If I'm hitting the rpm limiter, then power is not a factor.
Old Sep 24, 2015 | 09:13 PM
z06801's Avatar
z06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond repute
Top of 5th racing a Evoms GT700 kit 997tt had him by a half a car. Calculated at 178 with my tire size. My UMW tune raised my limiter
