DV's replacing
Old Nov 21, 2003 | 06:07 PM
MJC123's Avatar
Senior Member
MJC123 has much to be proud ofMJC123 has much to be proud ofMJC123 has much to be proud ofMJC123 has much to be proud ofMJC123 has much to be proud ofMJC123 has much to be proud ofMJC123 has much to be proud ofMJC123 has much to be proud of
I forget if the stock ones are all plastic...but thought they were. These new ones are definitely all metal.
Old Nov 22, 2003 | 09:35 AM
hardwaykao's Avatar
hardwaykao is infamous around these parts
i have c2 not tt. should i also change my DV as well? sorry i don't have much knowledge on technical stuff.
Old Nov 22, 2003 | 10:21 AM
msindi's Avatar
I dont think NA cars have DVs...Main pont of a DV is to hold boost between shifts...
Old Nov 22, 2003 | 12:16 PM
oak's Avatar
oak
If your DV's are leaking Porsche will replace them with the new stock replacement "Baileys".
Old Nov 22, 2003 | 06:05 PM
msindi's Avatar
Oak - long time no see...BTW are u serious about Porsche using Baileys?? I personally doubt it asthey would at least use something German not English...
Can someone look into/verify this??
Old Nov 22, 2003 | 07:45 PM
oak's Avatar
oak
Hey msinidi, it's a world economy. Porsche uses engine cases made in Spain, brakes made in Italy. Is my credibilty that bad?
Old Nov 22, 2003 | 08:04 PM
KPV's Avatar
KPV
And don't forget France!!
Old Nov 22, 2003 | 08:53 PM
Dock (Atlanta)'s Avatar
Dock (Atlanta) is just really niceDock (Atlanta) is just really niceDock (Atlanta) is just really niceDock (Atlanta) is just really niceDock (Atlanta) is just really nice
My dealer replaced my DVs with Baileys...under warranty.
Old Nov 23, 2003 | 01:14 AM
MJC123's Avatar
Senior Member
YAY! I'm not nuts!
Old Nov 23, 2003 | 12:24 PM
msindi's Avatar
interesting...So I wasted $300+ plus labor for something I could have gotten for free...DO you know what model Baileys they are using?? The one in MJC's pic does not look like my DV30s...
Anyone in Porsche parts here??
Old Nov 23, 2003 | 02:35 PM
The mechanic had a computer in his work area, and he ordered the Baileys on line from AWE. I don't remember the model number.
Old Nov 23, 2003 | 02:40 PM
Chordate's Avatar
Chordate is infamous around these parts
Do you have to prove something is wrong with your DV's? My car is new, and I don't hear andy honking noises, yet I would like to get Baileys.
Old Nov 23, 2003 | 02:43 PM
I wish I would have known that before I went ahead and purchased the Baileys on my own.
My DVs started "honking" at about 3500 miles. I told the dealer I wasn't about to have the valves replaced with OEM valves and just be back 3500 miles later to have the same thing done again, especially when there was a guarenteed fix out there (Baileys). I told them the car was too expensive to have to deal with a pain in the rear bad part, and I expected it fixed the first time.
They agreed.
Old Nov 23, 2003 | 03:00 PM
I think you'd be hard pressed to get the valves replaced with Baileys under warranty if you can't demonstrate a problem.
Mine were "honking" so it was a no brainer.
Except fot the noise being gone, I couldn't tell any difference in performance with the Baileys installed.
Old Nov 23, 2003 | 05:40 PM
msindi's Avatar
Replacing the DVs is not meant to increase performance but rather reduce the possibility of them failing and thus reducing performance by leaking turbo boost...
