100 Cell cats = Check Engine Light ?
Hi,
I might consider adding an exhaust system with 100cell cats to my 2003 TT non X50. I am also planning on chipping the car to stage 2, or 3 with new wastegate and intake system (but keeping the K16). My concern is would 100cell cats be a problem with either the turbo's overspooling and CEL (that is what I read so far from 2 users).
Bo
Bo
Re: 100 Cell cats = Check Engine Light ?
Originally posted by Mz3bo
Hi,
Bo
Hi,
Bo
Exhaust from AWE Tuning
my 100 cats lasted about 15K b4 a cel
2001 996TT 3.6L and stock ECU
If I understand correctly, the number of cells corresponds to the number of holes per square inch. The fewer holes, the lower the differential pressure resulting from air flow through the cells. Since airflow through a pipe and the resultant differential pressure follows the "Square Law", ie. as flow goes up, differential pressure goes up exponentially, 100 cells are better than 200 cells. Unfortunately, residence time is important in the catalytic conversion process. So, a balance has to be struck to ensure that adequate conversion of the long-chain hydrocarbons takes place, so as to not kick off check engine light, while offering the best performance for your car.
What an F'ing Dork I've turned into!
Gee, it's a good thing I staye at a Holiday Inn Express last night.
Very thorough.
Mini George
Jul 29, 2019 12:20 PM
adnanm3
Oct 25, 2016 08:38 AM
oddjob142
Aug 19, 2015 12:27 PM
