Front Seat Removal
Old Dec 1, 2015 | 05:33 PM
996TWINS's Avatar
996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute
Front Seat Removal
Do I need to disconnect the battery when unplugging the front seat electrical connector to avoid any error codes or other issues?
TIA
Old Dec 1, 2015 | 05:35 PM
'02996ttx50's Avatar
i would if for no other reason than those seat belt connectors under there can get messed with and then you could get airbag errors. yeah.. i would = safe side.
Old Dec 1, 2015 | 05:36 PM
irish100p's Avatar
irish100p is a name known to allirish100p is a name known to allirish100p is a name known to allirish100p is a name known to allirish100p is a name known to allirish100p is a name known to all
If you have durametric, no, otherwise, yes. Also make sure everything is reconnected seat wise before you reconnect the battery.
Old Dec 1, 2015 | 05:52 PM
Jeanmarcboilard's Avatar
Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !
I forgot to unplug my battery before unplugging my seats and nothing happened.
Old Dec 1, 2015 | 05:58 PM
32krazy!'s Avatar
if you remove the seat belt connector that arms the airbag the light will go off and dealer has to reset
Old Dec 1, 2015 | 09:27 PM
996TWINS's Avatar
Got the air bag and seat belt light. At least my shop can do a reset.
Old Dec 2, 2015 | 02:21 AM
32krazy!'s Avatar
told ya.
Old Dec 2, 2015 | 03:40 AM
^ yup. looks like a trip to manny lol
Old Dec 2, 2015 | 04:50 PM
ghostofpain's Avatar
ghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to behold
As i installed my recaro pole position i didnt care about electrics. Nothing happend at all. The airbags got nothing to do with the seats. The 996 has no airbags inside them. Just dont operate while the ignition is on. The seat belt connector must be plugged in again and all is good.
Old Dec 2, 2015 | 05:02 PM
996TWINS's Avatar
Off to the track this weekend, and will get the ABS and seat belt lights cleared out while I am there.
Old Dec 2, 2015 | 05:28 PM
32krazy!'s Avatar
the seat belt connector tells the computer that theres a person in the seat and arms the airbag when the key is turned on. if you unplug the connector with the battery on you set off the airbag abs lights and dealer has to reset.
Old Dec 2, 2015 | 09:27 PM
LQQK's Avatar
LQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond reputeLQQK has a reputation beyond repute
I've successfully reset with durametric.
Old Dec 7, 2015 | 06:30 PM
split71's Avatar
split71 has a reputation beyond reputesplit71 has a reputation beyond reputesplit71 has a reputation beyond reputesplit71 has a reputation beyond reputesplit71 has a reputation beyond reputesplit71 has a reputation beyond reputesplit71 has a reputation beyond reputesplit71 has a reputation beyond reputesplit71 has a reputation beyond reputesplit71 has a reputation beyond reputesplit71 has a reputation beyond repute
x2
I just put in a set of OEM Euro GT3 seats. I had the factory seats out with the 4 bolts, disconnected the seat belt harness and swapped in the GT3 seats with no issues. And that's with the battery connected the whole time.
**KEEP YOUR KEY OUT OF THE IGNITION, if you do this then you won't trip the ABS light!
pureporsche
Mar 10, 2021 10:18 AM
tiennd
Cayenne 955/957
Dec 28, 2015 07:53 PM
BUTZI996TT
Dec 3, 2015 09:35 AM
NJGT3
Dec 1, 2015 10:46 AM
Alex Toth
Nov 30, 2015 01:04 PM
