Gearbox upgrade suggestions
Old Dec 7, 2015 | 07:44 PM
  #31
'02996ttx50's Avatar
Originally Posted by flewis763
I agree but what is damaged with a 2nd gear pop out, just the syncros or do the gears get damaged too? That's goes back to if I have to replace gears then I might as well do a few
the synchro's is what first causes "it" ( dogring gets rounded too ) and sometimes ( but not always ) 1&2nd gears, which incl new mainshaft. then you'll need to replace the bearings since you're in there anyway...and ( or i thought you said 3rd pops out?! ) then you need 3rd & synchros there too, so you need a full rebuild essentially.
they built with "triple cone" synchro's and everything is a trade off, but this one doesn't serve "most" of us. it was to make the 1/2 shifts buttery smooth. or so i was told.
Old Dec 7, 2015 | 07:58 PM
  #32
flewis763's Avatar
flewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond repute
2nd gear, I fixed that it was a typo. I'll have to make some calls on the 997 gt2 main shaft and see what pricing is. Really for my needs the gearing isn't to bad especially with going to a 325/30/19 rear. That's adds some mph to each gear but a little higher wouldn't hurt.
Old Dec 7, 2015 | 09:11 PM
  #33
it all depends on what your needs/goals for the car are and will be looking forward. so many people upgrade parts in a haphazard way and if you're not road coursing or tracking regularly and the car is primarily a street car, you'd *probably* be best served by refreshing everything that's faulty e.g. fixing what you've got.
i looked into different gear sets etc and who among us wouldn't like a taller first/second etc, but for what i do? it's a spend vs return kind of equation so i opted to stay oem and on top of maintaining what I've spent to rebuild/refresh. you have parts that need attention, so people will tell you to get gt2 stuff and there's all kinds of options. or just rebuild it oem, and take care of it once done! gl w it!
Old Dec 7, 2015 | 11:50 PM
  #34
pwdrhound's Avatar
Is that will all the gears it's under 2k?
Correct
mpwr626
SoCal
Dec 25, 2015 07:12 PM
stoney85
Cayenne 955/957
Nov 28, 2015 09:44 PM
little nellie
Nov 25, 2015 09:39 PM
exoticparts
Bentley
Nov 23, 2015 05:43 PM
E-Gear
Nov 15, 2015 03:56 AM
