Giro Disk...street review?
Curious if anyone has any recent feedback on the Giro Disk rotors on the street? My brakes are pretty solid as is, but with more power I want to start addressing suspension and brakes.
90% of my drive time is on the street, sometimes quite aggressively. The other 10% is on the track. For now mostly straight line 1/2 mile, but I want to get me feet wet on a road course (but I'll start that endeavor in my E46 M3)
I want to see if the Giro Disk upgrade is worth it for me or should I just get some nice pads, SS lines, and good fluid
[url=https://flic.kr/p/Bz8R86]
I would use Giros for your setup..
Strange as checked with AP racing and they say there is no AP product for 996tt... Went with 350/350 Giros for next year till will upgrade the calipers and move to 380/350
There is a 996/997TT application. I can get the AP racing stuff through my US distributor. I don't think you can get it in Europe however.. I run the AP 380/350 GT3 stuff but can get it in TT offset also. Same with 350/350. The AP stuff lasts quite a bit longer than Giro under hard track use. For the street it doesn't matter. Both are overkill
With proper cooling the stock 4/4 brakes are more than enough for anything you can throw at them on the street. The piston area is the same as on the 6/4 350/350 set up as the 6TT 4/4 calipers. The yellow 350 6 pots are 6GT2/3 calipers, the red version is a 997TT caliper. The GT version uses zircon piston puck heat insulators while the TT pistons are just steel. The yellow 380 997GT3 380 calipers that I run are physically slightly larger while using 20% less pistons area than the 996 cousins.. The 997 rear calipers are larger and have 50% more piston are than the 996 versions.
thx.. without going again into what type of "streets" i find myself on, i'm just trying to figure out whether or not the 6x4 combo would better suit what i do..and i bet it would, but stopping has never been an issue. but its too late as i have new painted stockers headed my way soon enough and should've considered that sooner. probably why i wasn't able to give those spare parts you had/have much more than a cursory thought as i'd already partially paid for the stockers to be redone! thx for the reply/info.
