Can I haz idiot's guide to tranny rebuild?
Old Jan 4, 2016 | 12:50 PM
pwdrhound's Avatar
Originally Posted by Turok
I will have the CAE, so I don't need the GT2 shifter.
The in car shifter has nothing to do with this. I'm talking about the transmission mounted shift lever. Apples and oranges...
Old Jan 4, 2016 | 06:16 PM
Turok's Avatar
Turok is infamous around these parts
Yeah, I've just read I think all of your messages about cup shifter on this board. Can you point to a part # for it?
Also, if I install a non-cup upper lever afterwards (the CAE, for example). Will they work together ok with no overkill?
Old Jan 5, 2016 | 02:11 AM
pwdrhound's Avatar
The transmission mounted lever part# is 9963030319A. You also need the bracket (996424165A) that aligns the cables with the shorter lever.
You can use whatever shift cables and shifter that you want. Stock, CAE, GT3, Cup, whatever... I would not use the 997SSK since the throw would be way too short. The 997SSK was designed for the long TT transmission lever.
Old Jan 5, 2016 | 09:54 AM
Turok's Avatar
pwdrhound, great. I updated my parts list on the first page!
The only issue I'm left with is steel synchros. To be or not to be?
I found these part #s on the Internet (the ones on the left are what I have now, stock brass):
95030461120 (synchro rings for 1 -2) --> 95030431130
92830421123 (synchro rings for 3 -4) --> 92830421130
Are these the right ones to go with the 7GT2RS mainshaft? There is a thread on http://rennlist.com/forums/911-forum...t-numbers.html, where Erik from GBox says to be cautious with these..
For some reason I see people using steel only on 3-6, not on 1-2?
Old Jan 5, 2016 | 12:19 PM
johnny.dangerous's Avatar
johnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud of
Im in a similar position in that im in a catch 22 scenario, I have Gt35's im barely using, if I build a motor for which I have a spare and many parts like Carillo rods etc I cant take advantage as Ill smash the box, I have a spare trans so have decided to build that with 2 piece solid mainshaft, SS syncros and straight cut 1,2,3 gears and extended 6th with a Quaife ATB diff and billet diff cover with uprated shafts, the only upside is I can launch the car harder and it will have more top end over our Vmax events which are around 1.3 miles, the whole car will come together when it has the built motor with 12mm studs and O ringed heads etc. But for now it has to be the box as I dont want to smash an expensive box that I could in effect sell to finance a large portion of my engine build, but I want a spare motor and box at all times.
Old Jan 6, 2016 | 02:28 AM
Turok's Avatar
bump, still need 'em steel synchro part numbers!
Old May 15, 2020 | 05:14 PM
HotRodGuy's Avatar
The taller 7GT2RS gearing is a must in my opinion. Huge upgrade over stock and 3rd gear is much beefier than stock 6TT 3rd... If you don't do this, you'll regret it. I know that's not what you wanna hear though.
what's the diff in mph with this gearing? Been looking all over.
Old May 15, 2020 | 05:58 PM
pwdrhound's Avatar
These are my speeds in gear with 1-4 7GT2 gearing, 5-6 6GT2 gearing. These are based on a 7500 redline and 27" tall rear tires. With a lower redline and smaller diameter tires, the speed will be manually less.
1st......55mph
2nd.....91mph
3rd.....123mph
4th.....158mph
5th.....187mph
6th.....230mph
Old May 15, 2020 | 06:18 PM
HotRodGuy's Avatar
Thanks bud!
Old Nov 24, 2022 | 12:53 AM
awdmig's Avatar
awdmig is a name known to allawdmig is a name known to allawdmig is a name known to allawdmig is a name known to allawdmig is a name known to allawdmig is a name known to all
Sorry for bumping old thread just can't get a definite answer. Are the 996 brass and 997 steel synchro interchangeable?
Franc01
Apr 9, 2018 11:47 AM
love2drive
Dec 21, 2015 08:55 AM
Red911TT
Dec 10, 2015 10:54 PM
DerekShiekhi
Lexus
Dec 8, 2015 02:15 PM
