Engine Drop with MaxJax and Floor Jack?
Old Jan 26, 2016 | 09:37 AM
pteck's Avatar
pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !
Steve, that cradle is just about the best one I've seen! Great job. Useful for probably even a table, as pics of the pro shops doing this with the table are using blocks of wood in the positions you have your risers at.
I'm leaning towards the table at the moment. But I've also got my crazy mind on using the motorcycle jack as a base for a reclining mechanics seat...
Just for kicks, I found this craziness:
Old Jan 26, 2016 | 04:10 PM
MadWhip's Avatar
MadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond reputeMadWhip has a reputation beyond repute
nice,- sooner or later i want that
Old Jan 26, 2016 | 04:15 PM
32krazy!'s Avatar
the thing to remember is that the bottom of the motor isn't flat. using the h/f table gives you a huge amount of room to set a block or 2 in place and the ability to start the motor to the table itself so theres uno chance of the motor tipping over or that huge mess of wood in that picture sliding out. it raises high enough (36" i think) so that a simple 2x4 is all thats needed . its really the safest way to remove the engine and trans
Old Jan 26, 2016 | 06:54 PM
Steve Jarvis's Avatar
Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !Steve Jarvis Is a GOD !
The motorcycle jack takes up less space when not needed.
My other considerations were that I the handle on the table would be in the way. I thought the handle would hit the rear chassis/heat shield when trying to push it under the car (since I was using jack stands).
Later, Steve
Old Jan 26, 2016 | 07:07 PM
32krazy!'s Avatar
Originally Posted by Steve Jarvis
Later, Steve
its ok to make the wife park outside so theres more room for tools! the handle isn't any issue the table is 32" long. lots of room for the driveline. theres also an additional 2.5" space from the edge of the table and the handle itself. this allows for the table to fully be under the car and not have the handle hit anything
Old Jan 26, 2016 | 08:04 PM
pteck's Avatar
Digging deeper looking at specs, some not so "lite" considerations.
Table con:
Wow, these tables are ~150 lbs themselves. I might need a hydraulic table to unload the hydraulic table from my SUV.
Motorcycle Jack pro:
Handles come off and they are ~5" flat to store. I like that!
Old Feb 2, 2016 | 02:05 PM
pteck's Avatar
I wound up picking up the table. Sturdy son#%!b*tch. I've yet to put enough time in the garage to drop the motor yet, but very soon.
I came across another option which seems really promising. I likely would have done it this way had I found it earlier:
Great engine drop thread with detailed info here:
https://www.6speedonline.com/forums/...lt-mods-3.html
Old Feb 2, 2016 | 02:09 PM
32krazy!'s Avatar
Originally Posted by pteck
I wound up picking up the table. Sturdy son#%!b*tch. I've yet to put enough time in the garage to drop the motor yet, but very soon. I came across another option which seems really promising. I likely would have done it this way had I found it earlier: Great engine drop thread with detailed info here: https://www.6speedonline.com/forums/...lt-mods-3.html
Did my first engine drop that way. Works but hard to maneuver around. Motor is fairly unstable unlike being on the table
Old Feb 4, 2016 | 07:15 AM
BauerR's Avatar
BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !
I made this form and used the motorcycle lift.
Here's a picture of when I pulled the engine/transaxle from the car. he nice thing is you can completely remove the jack handle, so it's not in the way.
[IMG]https://cimg3.ibsrv.net/gimg/www.6speedonline.com-vbulletin/2000x1504/80-img_2864_127b11e34856c2f5efe059617dc11bbd96dd459c. jpg[/IG]
[IMG]https://cimg8.ibsrv.net/gimg/www.6speedonline.com-vbulletin/2000x1504/80-img_2863_95bca9d146c07005efe7f5316616016b77e1bb3e. jpg[/IG]
Here's a picture with the lift in the up position, so I could work on the engine.
[IMG]https://cimg7.ibsrv.net/gimg/www.6speedonline.com-vbulletin/2000x1504/80-img_3010_ffaff6e4343ed698320471e49610698bac6d87ad. jpg[/MG]
I'm interested in this. Would you mind giving me the dimensions of the platform you made? Also, what motorcycle jack did you go with?
Thanks!
Rich
Old Feb 4, 2016 | 09:36 AM
pteck's Avatar
I'm not even an at the drop part of the procedure and the table is already coming in handy in many ways.
- Stable, adjustable height platform for me to step onto while the car is on the lift. I could just as easily bring the car down, but I'm primarily working underneath right now and it's easy to just step up onto the table to reach the engine bay.
- Bringing my oil catch or coolant catch to just the right height under the car, rather than lift specific catch containers.
HF surprised me this time. This table is incredibly well build and looks like it'll last.
Old Feb 4, 2016 | 12:36 PM
Thanks!
Rich
I'll try to get you some measurements.
I purchased the lift from HF.
Later, Steve
Old Feb 4, 2016 | 07:32 PM
BLKMGK's Avatar
Read some of the product reviews on that HF table. As I recall there were some weak points that were addressed by folks to make it even better. Really cool to see that HF doesn't seem to muck with stuff posted on their site, last I looked anyway!
Old Feb 5, 2016 | 05:40 PM
Hope this helps.
Old Feb 5, 2016 | 06:41 PM
Byron in Atlanta's Avatar
Byron in Atlanta is a splendid one to beholdByron in Atlanta is a splendid one to beholdByron in Atlanta is a splendid one to beholdByron in Atlanta is a splendid one to beholdByron in Atlanta is a splendid one to beholdByron in Atlanta is a splendid one to beholdByron in Atlanta is a splendid one to beholdByron in Atlanta is a splendid one to behold
Steve....can you please tell us which types of wood you used? Any hardwoods?
Hope this helps.
Old Feb 5, 2016 | 09:15 PM
Just trying to help.
You work with whatever is laying around the house.
Later, Steve
