Navi swap in 2005 996 TT?
Old Dec 7, 2005 | 09:16 AM
sunracer's Avatar
sunracer is infamous around these parts
Just got a 2005 Turbo S cab and this is my first Porsche so I'm in learning mode right now...
Does anyone know how hard it would be to swap the navi head unit in my 2005 turbo S cab for an Eclipse AVN unit? I've installed the AVN in my last car so I'm familiar with it but I think that the 911 Navi may be tied-in to the cars computer with some sort of bus that might make this simple swap difficult...Scott
Old Dec 7, 2005 | 12:02 PM
Griza's Avatar
Griza has much to be proud ofGriza has much to be proud ofGriza has much to be proud ofGriza has much to be proud ofGriza has much to be proud ofGriza has much to be proud ofGriza has much to be proud ofGriza has much to be proud of
If you are able to switch it, I would be interested in buying the stock Nav from you.
Old Dec 7, 2005 | 03:05 PM
SG's Avatar
SG
SG has a spectacular aura aboutSG has a spectacular aura aboutSG has a spectacular aura about
are the 2nd generation navs easily replaceable with the ones on the '02's?
Old Dec 7, 2005 | 03:42 PM
Oliver B's Avatar
Oliver B is infamous around these parts
You can´t replace the PCMII in a early 02 Turbo. The new system use the MOST bus system.
Old Dec 7, 2005 | 04:12 PM
sunracer's Avatar
Does the MOST bus in the 2005 system make it impossible/impractical to replace the Nav/Radio?
Scott
Old Dec 7, 2005 | 04:24 PM
Griza's Avatar
Well, I guess I recind my offer
Old Dec 7, 2005 | 04:52 PM
Oliver B's Avatar
Scott
Don´t know, i think it will be very difficult. Ask you local porsche dealer. The only thing i know, you can´t swap pcm1 and pcm2.
Old Dec 7, 2005 | 05:17 PM
chucksweet's Avatar
chucksweet is a glorious beacon of lightchucksweet is a glorious beacon of lightchucksweet is a glorious beacon of lightchucksweet is a glorious beacon of lightchucksweet is a glorious beacon of light
Aftermarket Audio System in MOST based Porsche
I took the stock Navigation system out of my 2005 Boxster and installed a Pioneer AVIC D1. I replaced all of the speakers and the amplifier. Then I didn't have to worry about the MOST system. It works great!
Actually, the harder part for me was coming up with a good trim ring for the head unit.
Chuck
Old Dec 7, 2005 | 07:11 PM
sunracer's Avatar
That's good news since I would guess that the radio systems in the boxster and 911 are the same or at least very similar. The trim ring isn't a problem for me since I have a full machine shop...the wiring isn't a problem either as long as the Radio/Nav isn't somehow required to be connected to the othe rcomputers in the car...
Rguy
Apr 12, 2020 11:11 PM
digitalzombie
Sep 9, 2015 04:03 PM
ss2z06
Sep 9, 2015 11:46 AM
cporterfield
Cayenne 955/957
Sep 3, 2015 06:54 PM
the997dude
Sep 2, 2015 08:51 PM
