Here's one reason to replace brake pad dampeners
Old Mar 16, 2016 | 08:21 PM
Gixxed_Spyder's Avatar
Gixxed_Spyder is infamous around these parts
Unhappy Here's one reason to replace brake pad dampeners
...or atleast eject them. I was in the process of taking the calipers off to have them powder coated and both of my fronts had the dampener seized inside of the piston...sprayed down with PB Blaster, let it soak and still no luck getting them out. I ended up taking it to a shop, once they get the piston out I'm hoping they have some sort of jig or tool that can yank on the screw and hold the piston in without damaging it.
Anyone else run into this? If so, how'd you fix it?
Last edited by Gixxed_Spyder; Mar 16, 2016 at 08:31 PM. Reason: forgot to attach picture
Old Mar 16, 2016 | 09:27 PM
vogz's Avatar
vogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond repute
I don't even use front dampers at all. No squealing issue either. Looks like a pain in the ***. Good luck!
Old Mar 17, 2016 | 06:24 AM
tropicatango's Avatar
tropicatango has a spectacular aura abouttropicatango has a spectacular aura about
remove the screw, make sure everything is flat and leave it there, it doesn't change anything
i have one in a front caliper too, pad dampeners are real junk if you ask me
pwdrhound
Apr 6, 2019 10:19 AM
Lotus Man
Mar 15, 2016 08:32 PM
SeattleTurbo
Mar 11, 2016 06:57 PM
XPEL
Tesla Motors
Mar 11, 2016 01:31 PM
