K16 install
Old Mar 20, 2016 | 10:37 PM
996tt550hp's Avatar
996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute
That dyno chart is flawless. Nice job yeah as you can see your toque is around 180hp from 3k to 4krpm which saves your rods plus he didnt let it all at once. Great AFR's too. Why isnt he on the boards here???
Old Mar 20, 2016 | 10:41 PM
pwdrhound's Avatar
Kevin's on Rennlist. He's a real good dude. Doesn't try to squeeze out the last couple of Hp for the sake of safety. He's very conservative.
Old Mar 20, 2016 | 10:43 PM
996tt550hp's Avatar
Yeah i was going to use him but never got around to use him 3 years ago. Tpny at epl got this tune dead on for these new turbos. How much boost were u running?
Old Mar 20, 2016 | 10:49 PM
pwdrhound's Avatar
Same turbos after we put in rods. Again 91 octane. Kevin retuned it and started bringing on hp/tq earlier shifting the power curve quite a bit to the left. Smooting is 4 instead of 5 so the graph is a little more jagged. Ignore the AFRs as the tailpipe probe was not inserted fully into the exhaust. Logs showed it right at 12.0 across under load.
[url=https://flic.kr/p/vqFY49]
Old Mar 20, 2016 | 10:50 PM
pwdrhound's Avatar
Boost is 1.25 bar running 100 cell HJS Motorsport cats and stock MAF which is scaled about 10% over it's limit. Power is essentially capped by the MAF.
Old Mar 20, 2016 | 10:54 PM
996tt550hp's Avatar
Wow at 91octane it seems to run great at 18+ psi
I have went at 683awhp at 19.3psi but lowered it after the dyno. Back to 18psi. Im still on stock rods.
Old Mar 21, 2016 | 05:38 AM
BauerR's Avatar
BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !
Originally Posted by BLKMGK
Yeah, boost isn't the issue cylinder pressure is and high torque is an indication of it. Maybe pull some timing to soften it up, might even speed spool?
I'm in VA as well and so long as we can pick a central point and get a few peeps together I might be down. Can't wait to get my car back lol!
Originally Posted by BenTT
Running a magic UMW clutch lightweight flywheel etc. on a dynacom dyno
Bauer pm me tons of cool events coming up in March April with convoys. I'm in Baltimore now.
Are you guys planning on going to Hershey?
Awesome event in VA This sat called fraggle rock. Basically exotic cars fill a neighborhood in centreville
I would be up for this but I'm headed to Colorado for some snowboarding!
Old Mar 21, 2016 | 06:46 AM
tomluice's Avatar
tomluice is infamous around these parts
k16 billet turbo rocks! I am lucky to own it.
Old Mar 21, 2016 | 06:47 AM
tomluice's Avatar
Smile Great choice
Old Mar 21, 2016 | 07:23 AM
stevemfr's Avatar
stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !
...your toque is around 180hp from 3k to 4krpm...
Old Mar 21, 2016 | 08:54 AM
996tt550hp's Avatar
Meaning how much torque occurs in a 1k rpm range to much torque will bend a rod. As shown from the OP he will bend his rods with that tune.
Pdwrhound will not bend a rod because his torque is not instant and its lower in a 1k rpm span.
Old Mar 21, 2016 | 09:04 AM
levinsje's Avatar
levinsje is a splendid one to beholdlevinsje is a splendid one to beholdlevinsje is a splendid one to beholdlevinsje is a splendid one to beholdlevinsje is a splendid one to beholdlevinsje is a splendid one to behold
You've got me worried about bending rods now.
On my stock engine I have K16 billets, 60# injectors, 1.25 bar Markski tune, 93 octane, IPD plenum, upgraded intercoolers, etc. The tune has been tweaked to my car with multiple durametric data logs. I only take my 996T to the track 3 or 4 days a year max.
Now I just modulate the throttle and do not floor it until I am about 3500 rpm.
Should I be more conservative and wait for WOT until 4000 rpm?
Old Mar 21, 2016 | 09:09 AM
996tt550hp's Avatar
No you dont need to worry markski knows what he is doing.
If you look at the first post at tge OP dyno chart this is what you do not want to see on a k16g. 650hp torque. The lines are dipping and not steady which means knock is happening and timing pulled. Installing a 5bar and not retuning and running 1.3bar on stock injectors. Also the instant torque is way to high.
I do wait to floor mine around 4k rpm in a higher gear it puts less stress on the rods.
Old Mar 21, 2016 | 09:19 AM
levinsje's Avatar
Thanks for the quick reply.
Old Mar 21, 2016 | 09:20 AM
996tt550hp's Avatar
Your welcome also you might be thinking pwdrhound is also high in torque but he has upgraded rods.
