K16 install
Old Mar 21, 2016 | 09:24 AM
  #31
stevemfr's Avatar
stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !
Originally Posted by 996tt550hp
Meaning how much torque occurs in a 1k rpm range to much torque will bend a rod. As shown from the OP he will bend his rods with that tune.
Pdwrhound will not bend a rod because his torque is not instant and its lower in a 1k rpm span.
I was referring to: "...your torque is around 180hp..."
Old Mar 21, 2016 | 09:27 AM
  #32
996tt550hp's Avatar
996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute
Meaning from 3k to 4k rpm. The torque is 180 torque on pwdrhound from that range.
The OP is 300 torque in that range which is not good and timing is being pulled.
Old Mar 21, 2016 | 09:35 AM
  #33
stevemfr's Avatar
Torque is hp? You do realize that torque is not measured in hp?
That is what I meant.
Old Mar 21, 2016 | 09:40 AM
  #34
996tt550hp's Avatar
Sorry i just put it at the end of the numbers but yes i know its not hp its just torque.
Old Mar 21, 2016 | 09:47 AM
  #35
stevemfr's Avatar
Or it could be ft-lb. Or Nm. Or a variation on distance/force units.
You really laid into the OP in post #15. Might want to apologize for that.
Old Mar 21, 2016 | 09:50 AM
  #36
996tt550hp's Avatar
Not really he doesnt listen this is why people blow there stuff up.
Old Mar 21, 2016 | 04:32 PM
  #37
BenTT's Avatar
BenTT is a splendid one to beholdBenTT is a splendid one to beholdBenTT is a splendid one to beholdBenTT is a splendid one to beholdBenTT is a splendid one to beholdBenTT is a splendid one to beholdBenTT is a splendid one to behold
Dude! Chill out! I never said you were not a tuner. Never once did I have anything negative to say about you.
You could be the best tuner in the world. I just happen to be working with someone else.
I'm always open for opinions. The tuner who I am working with has definitely recommend installing injectors and going back to stock FPR. We are going to do a custom tune when the injectors are installed. I do not want to blow my car up so I am happy to hear ideas.
Old Mar 21, 2016 | 04:53 PM
  #38
su_maverick's Avatar
su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !
I think what 996 was getting at is be very careful with the low end torque on the tune as that is the weak point when you get into heavier mods with the car.
Good luck with getting it ironed out!
Old Mar 21, 2016 | 04:57 PM
  #39
996tt550hp's Avatar
Were just telling you your tune is not good thats all. You can tell its leaning out and your timing is being pulled. You need to lower your torque way down also.
Old Mar 21, 2016 | 04:59 PM
  #40
BenTT's Avatar
This pull was a definite baseline to gather data we did not dare turn the boost up at all and my tuner is conservative. Before I run it at the wanna go fast half-mile event in Virginia it will have new injectors and be back on the original FPR and a custom tune. My tuner did highly complement Kevin and his tune! This forum is a great source of information about our cars.
Mach Schnell
Florida
Feb 26, 2016 08:39 AM
Mach Schnell
Scheduled Events
Feb 26, 2016 08:38 AM
pteck
Feb 24, 2016 03:56 PM
