what else should i be doing?
Old Mar 25, 2016 | 04:41 PM
Macster's Avatar
Originally Posted by BLKMGK
It's possible for a fuel system to lose pressure and cause a prolonged crank at start however this will NOT result in any particular cylinder having additional fuel nor is it caused by cracks in lines external to the tank. Fuel pressure on the high side runs at least 3.8bar and any cracks would spew fuel pretty good! Misfire is going to be injector, spark system, or timing related.
Yes, you are right, which is why I was reluctant to accept a fuel system supply/pressure problem as the root cause.
I'm leaning towards an injector or two as being the problem.
But I have to note the engine didn't misfire this AM nor at lunch. And it has done both of these earlier this week.
When it gets closer to time to change the oil/filter I'm going to try a bottle of Techron to see if that doesn't help. In fact I probably should have tried a 2nd bottle of the stuff the tech gave me and I would but I don't recall the name of the fuel system/engine deposit cleaner. I can remember Techron though.
Old Mar 27, 2016 | 06:10 AM
Ronny-'s Avatar
Ronny- has much to be proud ofRonny- has much to be proud ofRonny- has much to be proud ofRonny- has much to be proud ofRonny- has much to be proud ofRonny- has much to be proud ofRonny- has much to be proud ofRonny- has much to be proud ofRonny- has much to be proud of
Originally Posted by e8_pack
Any P/N's for the check valves? i had a brake pedal that kept going hard on boost so sure it was one leaking.
I found three check valves, one that has failed on mine and several others
99611013570
And two i've never heard about failing.
Both has 96411095001
And what a ridiculous listprice at 44bucks a piece.
For this..
http://www.autohausaz.com/images/96411095001.jpg
Jcusa
Apr 3, 2016 09:34 AM
estoril4dr
Mar 9, 2016 06:58 AM
Leslierc
Cayenne
Feb 25, 2016 05:05 PM
4KB
Bentley
Feb 24, 2016 06:46 AM
Josh/AWE
997 Turbo Vendor Classifieds
Feb 23, 2016 08:56 AM
