The actual weight of the 996TT...
Old Dec 16, 2005 | 05:38 PM
Divexxtreme's Avatar
I've read some threads that state the 2001 model year was lighter than the rest. 3,395 lbs for 2001 compared to 3,505 for newer year coupes.
I realize the glovebox and some other small items were not available on the '01's but they don't seem like items that could possibly add 110 lbs.
I also read that some people claim 3,395 is the "dry" weight for the car and 3,505 is the "wet" weight. But the fuel alone weighs 110 lbs. If the weight given for the 2001 cars was truly a "dry" weight (meaning zero fluids in the car) you'd be looking at a difference much greater than 110 lbs. More like 200 lbs or more.
So has anyone ever gotten the final answer on this one? Do the 2001's truly weigh 110 lbs less or not?
FWIW...I weighed my car (lightly optioned 6-MT Coupe with sunroof) on a certified and calibrated truck scale recently and it weighed 3,390 lbs with 5 gallons of fuel (i.e. "Unladen"). It has roughly 80 lbs of weight reducing mods installed....but I'm also running wider HRE 545's and larger tires so that adds some weight as well.
Old Dec 16, 2005 | 05:51 PM
Dock (Atlanta)'s Avatar
Dock (Atlanta) is just really niceDock (Atlanta) is just really niceDock (Atlanta) is just really niceDock (Atlanta) is just really niceDock (Atlanta) is just really nice
My 2002 owner's manual lists my Turbo at 3395 lbs "empty weight"...same as an '01.
My '02 with a full tank of gas, sunroof delete, floor mats, power lumbar both seats (my only options), and no occupants weighs 3480 lbs (weighed on four pad scales good to .025% accuracy).
Old Dec 16, 2005 | 06:01 PM
Okay...so I had 80 lbs less fuel weight, 80 lbs less weight from mods. But I have to add 40 lbs more weight for my sunroof...plus some weight for my power/heated seats (not sure how much that is...maybe 20 lbs?).
So taking those things into consideration, that puts us within 10 lbs of each other.
Old Dec 16, 2005 | 07:45 PM
jgraham's Avatar
jgraham is infamous around these parts
My turbo cab weighed 3666 lbs with me (125 lbs) in the driver seat when I had it corner balanced.
Old Dec 16, 2005 | 08:06 PM
JASCLASS's Avatar
JASCLASS is infamous around these partsJASCLASS is infamous around these parts
The 01 was the lightest of the 996 TT.
Old Dec 16, 2005 | 08:12 PM
iLLM3's Avatar
Wow very interesting
Old Dec 16, 2005 | 08:36 PM
Ruiner's Avatar
My '01 6spd, with a 1/4-1/2 tank of gas and a small suitcase in the front, was right around 3420lbs if I remember correctly (w/o me in it). I was bone stock at the time.
Old Dec 16, 2005 | 08:50 PM
How much difference is there between the '01 and the '02? Porsche claims they both weigh the same.
Old Dec 16, 2005 | 10:31 PM
AIRjordan23's Avatar
AIRjordan23 is infamous around these parts
scott, what are your 80lbs of weight reducing mods? light battery and exhaust?
Old Dec 16, 2005 | 11:43 PM
Turbo Fanatic's Avatar
All I know is that these cars have a TINY fuel tank. It's pretty annoying having to fill up so often!
Old Dec 17, 2005 | 08:12 AM
aracerx's Avatar
aracerx is infamous around these parts
corner balancing a turbo cab is like putting JABA THE HUT on a scale! VERY funny-Albeit awefully interesting when you consider the lightest 996's weigh in at 2540!
I can tell u; a truly lightweight Turbo (RS) without traction control and running 1 bar boost. No mods (OK..bilsteins) and some Michelins
is a KICKASS piece of equipment!
Old Dec 17, 2005 | 08:14 AM
aracerx's Avatar
OMT-Gotta dump that big pumpkin under the gas tank-"dat's for goils"! M havefunloseweightdriveturbo's
Old Dec 17, 2005 | 08:41 AM
Yep...battery, exhaust and removal of spare tire and jack. Now I just need a coil-over to corner-balance her.
Old Dec 17, 2005 | 09:22 AM
rmrmd1956's Avatar
rmrmd1956 is a glorious beacon of lightrmrmd1956 is a glorious beacon of lightrmrmd1956 is a glorious beacon of lightrmrmd1956 is a glorious beacon of lightrmrmd1956 is a glorious beacon of lightrmrmd1956 is a glorious beacon of light
My '01 weighted 3459lb full of fuel. It has a sunroof and the only weight changing mod was an EVO exhaust(~20lb saving)
Old Dec 17, 2005 | 09:48 AM
Ruiner's Avatar
GT3 seats would help.
