Replacing F pipe?
Replacing F pipe?
I failed my boost leak test today.
Looks like my F pipe has a crack in it. Do these go bad often? Should I just upgrade to a silicone one form Evoms or do another OEM rubber one? Should I replace DV valves too if I plan on doing a tune later this year while I'm there or just replace the f pipe and leave DV valves alone until they need replacing?
What do you guys recommend? I would probably just do 710n valves if I should replace them now.
Ha Vogz!
Forge Black f-pipe and 710N valves are on order from ECS tuning.
I think this one will hold better then the rubber pipe:
https://www.ecstuning.com/Porsche-20...ake/ES2550549/
flatsixing
Dec 2, 2023 12:47 AM
jetfuelonly
10
Jun 5, 2018 12:04 AM
joetwint
Apr 7, 2016 06:13 PM
