Engine Out. What more shall I do/buy?
Old May 19, 2016 | 05:17 PM
OK51MON's Avatar
OK51MON is infamous around these parts
Question Engine Out. What more shall I do/buy?
Old May 19, 2016 | 05:24 PM
32krazy!'s Avatar
replace all your vacuum lines and coolant hoses with new rubber. tie wrap every line you can find. replace #16 check valve. semi solid motor mounts.
Old May 19, 2016 | 05:33 PM
OK51MON's Avatar
Sensors?
Old May 19, 2016 | 05:42 PM
YJosephTT's Avatar
YJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond repute
clutch?
Old May 19, 2016 | 05:46 PM
OK51MON's Avatar
Its a tip
Old May 19, 2016 | 06:48 PM
996TWINS's Avatar
996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute
My car has been in the shop for some upgrades, fixes, and preventativemaintenance. Here is the list in no particular order:
Coolant pipe fix
Expansion tank
Water pump
Check valves (I thought there was only one, but there are two)
Oil pressure sending unit
Metal turbo oil feed lines checked
Waste gate vacuum lines
5 bar fuel pressure regulator
Clutch kit
Slave cylinder (found it was leaking a bit with the engine removal. Badnews/good news)
Pressure accumulator
Spark plugs
Water hoses
Fuel filter
Air filter
Crankshaft seal
Boost pressure test
Wastegate adjust
Endless brake fluid
Coolant
Throttle body seal
Precision Porsche GT2 deck lid (wing painted matte black)
GT2 deck lid wiring harness
Transponder
Coil packs
Solenoid brackets
Engine mounts (RSS)
Trans mount (997 version)
Multi-rib belt
2nd gear detent
Old May 21, 2016 | 04:05 AM
OK51MON's Avatar
Anything else?
Old May 21, 2016 | 08:10 PM
32krazy!'s Avatar
Originally Posted by OK51MON
Anything else?
rods ,head studs, 997 lifters, tons of head work, 3.8 piston liner ring set , all the internal paerts to make huge power!!
Old May 23, 2016 | 06:29 AM
ASLAN's Avatar
ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !ASLAN Is a GOD !
Maybe intake pipes. What have you done about ICs?
Old May 23, 2016 | 10:35 AM
OK51MON's Avatar
intake pipes will be fabricated . 997 gt2rs intercoolers
Thoughts?
Thoughts on power production ? 600 crank bhp?
Old May 23, 2016 | 11:09 AM
32krazy!'s Avatar
intake pipes will be fabricated . 997 gt2rs intercoolers Thoughts? Thoughts on power production ? 600 crank bhp?
skip them get 4.5" and dont look back
Old May 24, 2016 | 03:59 AM
ASLAN's Avatar
I think you'll be there with the right tune.
Old May 24, 2016 | 06:27 AM
brnrdtns's Avatar
brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !
bbi underdrive pulley is worth 7 to 10 while saving your PS pump at the track.
flewis763
Jun 25, 2016 05:54 AM
shaunsak
Mar 24, 2016 08:05 PM
Edreamsz
Mar 23, 2016 07:52 AM
