AFR/Lambda Question
Old May 23, 2016 | 03:43 PM
gregp714's Avatar
gregp714 has a spectacular aura aboutgregp714 has a spectacular aura aboutgregp714 has a spectacular aura about
AFR/Lambda Question
I have a 2003 turbo that is stock, except for an EPL tune. I do not have a Durametric to log with but I do have the DashCommand app that registers a few key metrics.
My idle AFR is 14.4:1 and my WOT in 3rd gear AFR averages at 11.08:1 (high of 11.62:1 and low of 10.70:1 during the few pulls I have done). Does this seem to be too rich at WOT or does it seem reasonable?
Thanks!
Old May 23, 2016 | 04:21 PM
Aktavate's Avatar
Aktavate is a glorious beacon of lightAktavate is a glorious beacon of lightAktavate is a glorious beacon of lightAktavate is a glorious beacon of lightAktavate is a glorious beacon of light
Sounds about the same as mine, I'm guessing Tony keeps it conservative because they are stock generic tunes. It has to safely cover a lot of cars in a lot of different conditions.
Old May 23, 2016 | 05:00 PM
32krazy!'s Avatar
typical epl tune
Old May 23, 2016 | 05:06 PM
YJosephTT's Avatar
YJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond reputeYJosephTT has a reputation beyond repute
My EPL tune is a bit rich also. I should be sending Tony my car wash bills, LOL.
I sent tony some logs and he said it was fine.
Can you record the AFRs timing and rpm etc., if so send tony the logs to review doesn't have to be durametric.
Old May 23, 2016 | 05:07 PM
02black330ci's Avatar
02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !
Yup sounds about right for EPL.
gregp714's Avatar
Perfect, thanks guys. Everything on the car seems to be running great but was just curious about this.
I will send Tony what I can log and get his thoughts too.
Old May 23, 2016 | 05:13 PM
32krazy!'s Avatar
dont bother. get a cobb tuner and have mitch load a file then datalog with the tuner and see exactly were you need to be
Old May 23, 2016 | 05:43 PM
BLKMGK's Avatar
Fuel changes won't make a ton more power in my experience and going lean can have "bad" consequences. Timing is where most power is made. Slap a car on a steady state dyno*, hold a load, and you can move fuel around a point or so and see small changes, move timing and changes are much greater. I'm okay with a rich tune under power but want it lean for cruise
*DynoDynamics are awesome for this, I badly wish I had regular access to one these days!
Fadi's Avatar
Fadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond repute
too rich, probably 0.8 lambda or 11.76 AFR would be a good and still safe/rich enough target even for 1000hp.
you are waisting fuel and power with low11/high10s. also no need for 14.4 as 14.7 works best, can you see also AFR target ?
flewis763
Jun 25, 2016 05:54 AM
giggalo
Apr 25, 2016 10:55 PM
BUILT4BOOST
Apr 24, 2016 07:27 PM
SSMugen
Apr 2, 2016 10:31 PM
audis4ever
Mar 22, 2016 08:26 PM
