996 wheel bolts / studs
Old Jul 8, 2016 | 01:11 AM
ghostofpain's Avatar
ghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to behold
H&R stuff is solid, cause it got tested by some old picky german engineer
Old Jul 8, 2016 | 09:14 AM
TiKORE's Avatar
TiKORE is a glorious beacon of lightTiKORE is a glorious beacon of lightTiKORE is a glorious beacon of lightTiKORE is a glorious beacon of lightTiKORE is a glorious beacon of lightTiKORE is a glorious beacon of light
Give us a call #weLUGwheels
CFallon@tikore.com
Old Jul 8, 2016 | 10:35 AM
911mhawk's Avatar
911mhawk is infamous around these parts
Exactly why I like to use Porsche parts and other proven hardware. Somewhere between German air for tires and Chinesium metal for lugs is fine for coffee & chamois.
Old Jul 8, 2016 | 08:10 PM
32krazy!'s Avatar
so what size studs are used if your running gt2 width and wheels?
Old Jul 8, 2016 | 09:59 PM
911mhawk's Avatar
Trick question?
I went with the longer ones for ease of use, work fine with stock and gt2 sized wheels. Added bonus is you can swap wheels very quickly, especially using rear jack points.
Old Jul 8, 2016 | 10:07 PM
pwdrhound's Avatar
H&R studs part number 1454005 is what you want Steve. Torque the studs at 32 ft.lb into the hub. Use with Porsche OEM steel lug nuts and torque to 118 ft.lb.
Old Jul 8, 2016 | 10:36 PM
911mhawk's Avatar
Originally Posted by pwdrhound
H&R studs part number 1454005 is what you want Steve. Use with Porsche OEM steel lug nuts and torque to 118 ft.lb.
Is it typical to torque them higher?
I've just kept with 96ftlb.
Old Jul 9, 2016 | 01:32 AM
pwdrhound's Avatar
96 is what's in the manual but it's a carryover from the old Porsche days when the cars used press in studs and aluminum lug nuts. As a matter of fact, all 991 cars call for 118 and they have the same sized 14x1.5 lug bolts. For street use 96 is fine but I found that at 96 I would need to retorque my wheels after every track session. At 118 I no longer need to do that. I torque them once and I'm set. I've also never broken a stud at 118 while I have seen and read about guys breaking them at 96. I think what happening is that at 96 the load on the wheel is allowing a certain amount of flex to be transferred to the stud which eventually fatigues and cracks, sort of like a paper clip that fails when flexed back and forth. At 118, flex is minimized if not all but eliminated. We use 118 on all of our race cars which use studs and I recommend 118 even with OEM lug bolts.
Old Jul 9, 2016 | 05:39 AM
32krazy!'s Avatar
Trick question?
no legit question. depending on who makes them i have seen at least 3 different lengths of studs. i dont mind seeing the end of the stud but dont want it sticking out of the wheel a 1/2" if not needed
Old Jul 9, 2016 | 09:34 AM
gophaster's Avatar
gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !
pwdrhound, always making our lives easier with part numbers. Always very much appreciated BTW, do you have a part number handy for the OEM lug nuts? Also just curious, what Porsche application(s) are they normally from?
Thanks 'hound!!
Old Jul 9, 2016 | 09:51 AM
pwdrhound's Avatar
Thanks 'hound!!
The lugs are part number N0201121. They are from old school cars like the 356, 911,912, etc, etc.. On the later cars they went to the black aluminum lug nuts.
http://www.new-part.com/product/pors...FQqoaQodDy8FKA
Old Jul 9, 2016 | 10:31 AM
911mhawk's Avatar
I'll measure mine Tuesday night before going to the track Wednesday and post pics with stock, OZ and F14s so people can see the look. I chose mine because they were black with bull nose and proven quality.
Old Jul 9, 2016 | 10:44 AM
911mhawk's Avatar
Noticed the same thing about having to retorque at 96 to the point where I have been getting neurotic. The bolts I had snap last year helped cause that too.
Switching to 118, thanks John
flatsixing
Dec 2, 2023 12:47 AM
mikaljun
Mar 25, 2016 06:14 PM
ECS Tuning - VW
Mar 25, 2016 08:28 AM
PelicanParts.com
BMW Vendor Classifieds
Mar 22, 2016 12:26 PM
