Mafless and installing SRM plenum, 82mm TB and their Y-pipe. What check valves....
Old Jun 12, 2016 | 12:03 PM
BauerR's Avatar
BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !
And other hard-to-reach items should I replace once I'm in there?
Old Jun 12, 2016 | 12:56 PM
32krazy!'s Avatar
i would swap every vacuum line i could get to. new check valves also new t/b gasket. add t clamps every were you can fit them. and of course tie wrap everything
Old Jun 12, 2016 | 01:48 PM
BauerR's Avatar
Any quick diagrams that can identify the check valves that will be accessible? Want to order those ahead of time
Old Jun 12, 2016 | 03:37 PM
32krazy!'s Avatar
Old Jun 12, 2016 | 05:03 PM
geetee's Avatar
geetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant future
#16 check valve and attachment hoses
venturi tube and new hose
2x #21 check valves
as many molded hose 92857471705 as you can.
those molded hose leak often
Old Jun 12, 2016 | 05:05 PM
geetee's Avatar
where are you finding these srm products? i don't see them on their site
Old Jun 12, 2016 | 07:39 PM
BauerR's Avatar
Thanks for your help, guys!
Geetee, SRM really needs to update their website. They have a lot more products than what they have listed.
Old Jun 12, 2016 | 09:33 PM
timccloud's Avatar
timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !timccloud Is a GOD !
Thumbs up
+1
Old Jun 14, 2016 | 12:53 PM
awdbiturbo1's Avatar
awdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant future
is the # 16 check valve (part number 996 1101 3570) the same check valve as the check valve on the #19 hose?
Old Jun 14, 2016 | 04:57 PM
GTstreet996's Avatar
GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !
I was under the impression that most were changing to billet check valves for the leaking intake manifold valve.
Old Jun 14, 2016 | 05:06 PM
BLKMGK's Avatar
Who makes a billet valve? So long as it didn't require lube or other maintenance I'd be interested next I find one leaking.
Old Jun 14, 2016 | 07:28 PM
I'm pretty sure Sean can get specific ones but generic 9-10mm billet check valves are everywhere. Ebay for example
Old Jun 14, 2016 | 07:52 PM
timccloud's Avatar
Really 9~10mm billet check valves cool can you post a link?
Old Jun 14, 2016 | 08:04 PM
geetee's Avatar
you mean the #21 check valve? They are different
Old Jun 14, 2016 | 10:58 PM
BLKMGK's Avatar
I'm aware of valves being available, industrial type uses etc would make sense. I'd just hoped that someone had figured out a good replacement as I'd expect crack pressure or vac to make a difference. One too low or too high might not work so well
