P1508 - Torque comparison function monitor
Old Jul 14, 2016 | 08:30 AM
Lucid Moment's Avatar
Lucid Moment is a name known to allLucid Moment is a name known to allLucid Moment is a name known to allLucid Moment is a name known to allLucid Moment is a name known to allLucid Moment is a name known to all
Have had this code pop up twice now. Once on the track a year ago under heavy rain, and this morning.
P1508 - Torque comparison function monitor - signal implausible
Loud pop, then no acceleration.
I clear the code and reset, and car runs fine.
Possible bad DME, software and MAF.
Running MAF less tune, physically removed MAF sensor, Cobb custom tune.
Most think it is the MAF sensor but I have not seen a specific solution and or reason for this code.
My guess is that the DME is fine, and obviously running mafless, so maybe a glitch?
If anyone has any more info that can help, please share.
Thank you.
Old Jul 14, 2016 | 10:54 AM
pwdrhound's Avatar
Limp mode. I got it when I forgot to tighten the clamp of the Ypipe. Large leak will cause this.
Old Jul 14, 2016 | 12:30 PM
No boost leaks, recently had motor out for several things everything tight. Drove it after clearing code and definitely hitting boost targets.
Old Jul 14, 2016 | 02:42 PM
but it was fine before you had the motor out right? if so, human error...
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Jul 14, 2016 | 07:40 PM
It happened about a year ago on the track, before the motor was removed.
Old Jul 14, 2016 | 10:21 PM
996tt550hp's Avatar
996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute
Yup had this code and my TB was dirty and had a leak there too. Clean it first and should be good to go.
Old Jul 15, 2016 | 02:13 PM
do you have a oem TB and plenum?
9.66
click to view
Old Jul 15, 2016 | 06:09 PM
Stock TB and plenum. Did have to TB out a while ago, and visually inspected it.
Old Jul 16, 2016 | 12:31 PM
996tt550hp's Avatar
Even tho the TB doesnt look dirty it is after years of running. Replace the gasket too.
Old Jul 16, 2016 | 01:22 PM
Ok, I'll check out TB. Problem is there really isn't a way to confirm if it solves the issue or not, because the code is sporadic and really no way for me to reproduce it.
Old Jul 16, 2016 | 01:24 PM
996tt550hp's Avatar
The code will not pop up again.
Old Jul 16, 2016 | 01:32 PM
Specific way to clean it?
Old Jul 16, 2016 | 01:33 PM
996tt550hp's Avatar
First you need the TB gasket then you unbolt it and spray it down with TB cleaner.
Old Jul 16, 2016 | 01:38 PM
Ok, appreciate the suggestion.
Old Jul 16, 2016 | 01:41 PM
996tt550hp's Avatar
Welcome. I hated that code.
