Yellow faded headlights be gone!
Old Aug 14, 2016 | 11:11 AM
Page's Avatar
Page is a glorious beacon of lightPage is a glorious beacon of lightPage is a glorious beacon of lightPage is a glorious beacon of lightPage is a glorious beacon of lightPage is a glorious beacon of light
How many cars on the road do you see with yellowing faded headlights.
Man I hated seeing my car like this, disgusted in fact. I've been putting it off for a while now. I like doing things on my own, but with so many projects and work, time kept slipping away. So finally got around to tackling this project.
I waited for a good stretch of weather (no rain) that wasn't too hot and fairly low humidity (under 50%-ish).
Took the headlights off the car and gave them a quick clean with soap and water.
I started out with 400 grit wet sandpaper (I pre soak the paper for a few mins) to quickly tackle the messed up UV coating (I use a small foam 3m sanding pad 05526). Quickly enough the yellowing was gone from the lights. Next was 800 grit (I sanded diagonally between each change of grit). You could stop there or finish up with 1000-1500. I used a small bucket half filled with water constantly cleaning and wetting the paper (change water when dirty). You can also use a spray bottle with water. Also continue rinsing the lights as you want to remove all the contaminants that you're sanding off.
Give them a good clean with soap and water to remove all residue from lights. Don't go to crazy with the hose as they are not 100% water tight.
Blow them off with an air hose (if you have a compressor) or dry them down with microfibre cloth.
Next is to prep where you will be clear coating them. You'll need a near dust free environment or best as you can find (could be done outside on a calm day). I have a shed that I put up plastic around the walls and floor. Al la Dexter! ;-)
Tape up the lights as best you can. First go around the lights with tape. I taped on the black rubber seal, just under the plastic housing. Then cover the housing with newspaper, any kind will do.
Place them where you will be spraying them. Then I cleaned the plastic lens with SEM 38353 Plastic & Leather prep. Best is to use a lint free towel. I used Scott Shop Towels, they are the best I had on hand.
Once I wiped them down, I gave them a quick blast of compressed air (Some use tack cloth to go over to remove any lint).
Make sure you wear a respirator when spraying!
Next was to use SEM 39863 Plastic Adhesion Promoter. Follow the instructions on can.
Then I used Eastwood 2 part 2k clear in a can. I have a compressor and spray gun, but didn't want to go too crazy with that setup for these. Also, follow the instructions on can. I gave them a light first coat, then waited 15-20 mins for the next. You should be able to get 3-4 wet coats with the can. The can has a nice spray pattern and flows well.
Let them dry at least 24-48hrs before wet wanding and polishing them. Don't wait too long, as the clear will harden and be more difficult to sand.
Remove all the masking.
I started out with 800 grit wet. Start with clean water and pre wetting the sandpaper. Wet the lights and start sanding. Use a small foam 3m sanding pad. But be careful, you don't want to sand through the clear coat after all the work you just went through. Be cautious of the lens. The center oval is ok, but there is a slight ridge towards the outside of the lens. Run your finger over it so you know it there (Some also put tape as a guide). Work the whole light to get the orange peel out. Rinsing the white milky residue as you go. Move up to 1500 and finish with 2500. Clean off the lens in between coats and use clean water.
Finally clean lens with soap and water. Dry and inspect and hopefully you haven't sanded through the clear coat!
Final stages will be polishing them up. You could attempt to polish them by hand, but that's a lot of elbow grease. I have a Flex rotary polisher I used with 4" pad.
You can use cutting compound of your choice. People swear by Meguiar's M105 and M205. I used what I had on-hand. Sonax nano polish with orange pad, followed up with 3m Lens & Hard cleaner polish with black pad.
Just with sanding, please be cautious when polishing, as you can also burn through the clear coat the same. I went max 1500RPM.
I will wait a couple of weeks for the clear to fully cure / harden, the I will put Xpel film on the headlights to further protect from the sun's UV rays and rock chips.
Old Aug 14, 2016 | 02:30 PM
996tt550hp's Avatar
996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute
This looks great man. I need to do this asap.
Old Aug 14, 2016 | 08:58 PM
Djohnson's Avatar
Djohnson is infamous around these partsDjohnson is infamous around these parts
Looks great.
Old Aug 14, 2016 | 09:34 PM
06Turbo's Avatar
06Turbo has a brilliant future06Turbo has a brilliant future06Turbo has a brilliant future06Turbo has a brilliant future06Turbo has a brilliant future06Turbo has a brilliant future06Turbo has a brilliant future06Turbo has a brilliant future06Turbo has a brilliant future06Turbo has a brilliant future06Turbo has a brilliant future
Nice step-by-step write up!!Keep in mind that your clear coat may turn yellow again if there isn't any UV protective agents in your clear coat. Ive tackled this job and used U-Pol clear:
So far has lasted the California sun without turning color.
Old Aug 15, 2016 | 07:13 PM
Page's Avatar
Thanks! Yeah, the Eastwood 2k clear has UV protection. I'm also going to put Xpel to further give it UV / rock chip protection. Wish I had a bigger garage, but mine is turned into a wood shop.
Old Aug 17, 2016 | 08:57 AM
gophaster's Avatar
gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !
Nice write up! I have been looking for an excuse to try that 2 part spray can clear. I've wondered how well it sprays out of the can and if it matches hvlp clear. Turned out great, nice job
Old Aug 17, 2016 | 07:32 PM
02black330ci's Avatar
02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !
Great job! They turned out completely new looking.
Old Aug 17, 2016 | 08:22 PM
Page's Avatar
Probably the best results you can from a rattle can. Just be careful if spraying from top, you might get a slight drip from nozzle. You will get orange peel, but it flattened out with sanding. Once again, just be cautious of the ridges on the lights when color sanding. Easily to rub through.
WheelB
Ferrari
Jun 7, 2016 02:49 PM
artyve
Apr 14, 2016 08:06 AM
tommyboy214
Apr 4, 2016 07:31 PM
Fuzzo
Cayenne 955/957
Mar 30, 2016 08:06 PM
dmvcarlover
Lamborghini
Mar 23, 2016 03:16 PM
