DIY - Create your own GT3 RS Wing
Old Aug 19, 2016 | 11:12 AM
REDLINER911's Avatar
REDLINER911 has much to be proud ofREDLINER911 has much to be proud ofREDLINER911 has much to be proud ofREDLINER911 has much to be proud ofREDLINER911 has much to be proud ofREDLINER911 has much to be proud ofREDLINER911 has much to be proud ofREDLINER911 has much to be proud of
Wow, that is really impressive. I thought this was going to be an off the shelf wing bolted to a decklid, lol. Any plans to make more of them now that you have all of the templates?
Old Aug 19, 2016 | 04:38 PM
z06801's Avatar
z06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond reputez06801 has a reputation beyond repute
I did a similar approach using my stock deck and fabricating a mount using the hydraulic ram mount point. Not as clean as Sliders but no modification to the deck was done. Two bolts and its off just leaving the ducktail. working on version #2 now.
ID:	456925   Click image for larger version
Old Aug 19, 2016 | 05:47 PM
DaveCarrera4S's Avatar
DaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond repute
Big thumbs up Slider! When can we get these on my website???
Old Aug 19, 2016 | 06:25 PM
32krazy!'s Avatar
Originally Posted by Slider
... yeah, sorry - the pictures are 1920 x 1280. I figured everybody could handle that these days - I could drop it to 1280 if people are having trouble...
no worries i was on my fone. heres a diy i saw at a car show. he used the ram holes to add some more air to the engine bay. so did you just use c/f and resin to hold the plate into the decklid? im guessing the entire lid is fiberglass? im trying to grasp how the uprights are mounted to the decklid and how it holds up under pressure at high speed
ID:	456937   Click image for larger version
Old Aug 19, 2016 | 10:27 PM
Slider's Avatar
I'm impressed... I thought the haters might come out and comment on putting a GT RS wing on a turbo. Thanks for all the comments - you guys are too nice!
Old Aug 19, 2016 | 10:35 PM
Slider's Avatar
Check out starting at picture #27... I made a steel insert for the stock fiberglass deck lid and used CF and epoxy resin to cement it in place. 3 Layers of CF hardens like steel - I used 3 layers on the back and about 5 on top. I then tapped through all of it for the bolts that hold the aluminum upright - That thing is never coming off.
Old Aug 19, 2016 | 10:36 PM
Slider's Avatar
Excellent compromise - I didn't want to damage my own deck lid either...
Old Aug 19, 2016 | 10:40 PM
Slider's Avatar
Ha! Funny you should say that... I thought I could do better and I'm 80% through version 2 myself. The initial deck lid and uprights are good enough but I thought I could do better on the wing by changing my approach on a couple of things. I think total time for wing #2 will be about a week but I'm hoping for absolute OEM quality on this one.
Old Aug 19, 2016 | 11:42 PM
s65e90's Avatar
s65e90 is infamous around these parts
Looks awesome. Forgive me for not clicking the link, but are you using inserts in the CF/Glass resin or just screwed the bolt through the resin?
Old Aug 19, 2016 | 11:49 PM
s65e90's Avatar
Just clicked through the pics. Fantastic work, especially when I see that you made the wing as well.
Old Aug 19, 2016 | 11:50 PM
Slider's Avatar
Like it says in your quote... I made a steel insert that I CFed into the deck lid... Click the slideshow - really - there is no advertising or anything - just a slideshow with 55 pictures of the progress.
Old Aug 22, 2016 | 03:44 AM
Mr. C4's Avatar
Mr. C4 is a splendid one to beholdMr. C4 is a splendid one to beholdMr. C4 is a splendid one to beholdMr. C4 is a splendid one to beholdMr. C4 is a splendid one to beholdMr. C4 is a splendid one to beholdMr. C4 is a splendid one to behold
Jeez, the trouble some people are willing to go through........great craftmanship though!
Old Aug 29, 2016 | 01:20 PM
VAGscum's Avatar
I posted a couple of pictures of car with my new wing and someone asked where I got it and suggested some people may be interested in the process I used to make my wing - so here it is Chris...
I took the measurements from a 997 GT3 RS. I first bought a used 996 turbo deck lid and cut the overhang off where it went over the lights and filled the wing holes. I used 3/16 th aluminum for all metal inserted into the wing as well as the uprights that hold the wing onto the deck lid. I used 1/8 th stainless steel inside the deck lid that I tapped to secure the uprights.
The wing is made of carbon fiber - 4 layers. I first made a form out of wood by starting with a steel rib and copying it to about 100 pieces of wood that I glued together to make the wing with the right profile. The attachment point is aluminum that was attached internally using more CF. The end blades on the wing were started with a piece of Plexiglas that I heated to bend and then covered in CF to get the size I wanted. There is an aluminum rib in the end of the wing that I tapped to allow the end blades to be screwed on.
I have a slide show that shows all the steps involved right here: GT3 RS Wing (1920 x 1080) GT3 RS Wing (1280 x 720)
The hardest part was fixing up the deck lid. Since that was the basis for everything I had to get that right.
I hope this helps anyone who wants to give this a shot...
Hard to tell from the slideshow, but dis you leave the wood form in as a base for the spoiler? Or did you remove it? What is the weight?
Old Aug 29, 2016 | 03:41 PM
Slider's Avatar
Definitely removed the carbon fiber from the wood and kept the form for future versions. I didn't weigh it, but I'm sure it's less than 5 pounds. 4 layers of CF and aluminum mounts - there isn't much bulk to it internally.
Old Sep 14, 2016 | 12:18 AM
h4nh's Avatar
h4nh is a splendid one to beholdh4nh is a splendid one to beholdh4nh is a splendid one to beholdh4nh is a splendid one to beholdh4nh is a splendid one to beholdh4nh is a splendid one to beholdh4nh is a splendid one to behold
Impressive craftsmanship!
