Misfires, urgent help needed!!
Old Aug 28, 2016 | 10:19 PM
mrmaass's Avatar
mrmaass has a reputation beyond reputemrmaass has a reputation beyond reputemrmaass has a reputation beyond reputemrmaass has a reputation beyond reputemrmaass has a reputation beyond reputemrmaass has a reputation beyond reputemrmaass has a reputation beyond reputemrmaass has a reputation beyond reputemrmaass has a reputation beyond reputemrmaass has a reputation beyond reputemrmaass has a reputation beyond repute
I don't want to start another oil debate...there are hundreds of 6S0 and rennlist forum pages dedicated to this topic, but running such high viscosity oils (10W-60) in the 996TT engine can lead to problems with Variocam plus opearation. The dual-lift intake lifters in particular are sensitive to this and can fail to operate properly if too heavy an oil is used. The oil passages that operate them are just too small.
Maybe if your car is used exclusively for tracking and oil temps are hotter than the average daily driver 10W-60 isn't a problem, but even then I was under the impression that heat is what cause all multiweight oils to gain viscosity up to their max rating, and 60W is far greater than the max recommended for our cars.
Mobil 1 5w-40 turbo diesel truck is a full synthetic and has the critical zinc levels that aren't present in their 0w40 in the current formula.
Old Aug 28, 2016 | 10:23 PM
996tt550hp's Avatar
996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute
Maybe if you're car is used exclusively for tracking and oil temps are hotter than the average daily driver 10W-60 isn't a problem, but even then I was under the impression that heat is what cause all multiweight oils to gain viscosity up to their max rating, and 60weight is far greater than the max recommendation for our cars.
Mobil 1 5w-40 turbo diesel truck is great and has the critical zinc levels that aren't present in 0w40 in the current formula.
I agree on this i forgot where they were talking about the oil being to heavy and bad. I run 5w 40 motul and thats it.
Old Mar 11, 2017 | 08:09 AM
pete95zhn's Avatar
pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !
Originally Posted by pete95zhn
BTW, I just changed to Castrol TWS 10W60, does thicker oil have any effect on VarioCam Plus' operation?
I guess this picture answers the question whether or not 10W-60 oil is suitable for Mezgers...
Old Mar 11, 2017 | 08:49 AM
s65e90's Avatar
s65e90 is infamous around these parts
you have no idea what the clearances are in that engine.
Old Mar 11, 2017 | 09:14 AM
pete95zhn's Avatar
I sincerely doubt that RUF has altered VarioCam Plus's clearances...
Old Mar 11, 2017 | 09:21 AM
s65e90's Avatar
bearing clearances. Bearing clearances are one part in dictating oil weight.
magoochi
Jun 12, 2016 09:07 AM
koenbro
Apr 23, 2016 04:48 PM
996TTer
Apr 17, 2016 10:41 AM
Brunno Cortes
Apr 3, 2016 10:33 AM
sporters78
Cayenne 955/957
Feb 12, 2013 07:24 PM
