Clutch issue?
Old Nov 8, 2016 | 08:44 PM
EdLebby's Avatar
EdLebby is infamous around these parts
Clutch issue?
in most gears (all?) when i get on it over 4k rpm something slips and the revs spike up without the car going any faster?
i am sure for those that know this means the XYZ has gone bad...can someone pls tell me what the XYZ is?
thanks!
Old Nov 8, 2016 | 10:48 PM
32krazy!'s Avatar
time for a clutch
Old Nov 9, 2016 | 05:34 AM
EdLebby's Avatar
What $ can one expect to replace with stock clutch, parts and labor, at an indie?
Thx
Old Nov 9, 2016 | 05:54 AM
32krazy!'s Avatar
1500$ for a decent sachs clutch and at least 8-10 hrs labor
Old Nov 9, 2016 | 08:46 AM
EdLebby's Avatar
thanks
Old Nov 9, 2016 | 03:21 PM
C1Forged's Avatar
C1Forged is infamous around these parts
While you're at it, get a full kit with a lightweight flywheel. It will increase response, and you wont have to resurface the wheel with the new disc and pressure plate. Might as well upgrade while you have the chance, and so it will hold up to more abuse.
Old Nov 9, 2016 | 06:03 PM
'02996ttx50's Avatar
^ with any/all respect, its best to ascertain what one's individual goals for the car might be, before recommending a clutch replacement utilizing a lwfw. while it is no doubt lighter, faster revving, its also capable of some major chatter making it a dubious choice for any primarily street driven 996 turbo.
i second 32's assessment of estimated hourly labor/parts etc. on mine, we did it on a rented lift in 6 hrs +/- using all sachs oem w my only add on being an unsprung gt2 clutch disc.
me, i like the quiet oem clutch but no doubt about it. a lwfw has some definite advantages having less,.. umm, mass lol.
Old Nov 9, 2016 | 06:29 PM
EdLebby's Avatar
i will be driving only on the street (daily) and i am looking to keep it stock...thanks for the suggestions though...very helpful
Old Nov 9, 2016 | 07:03 PM
Sachs 2.5 clutch and call it a day.
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Nov 10, 2016 | 05:51 AM
joey996tt's Avatar
joey996tt is infamous around these parts
^^ not worth going back to a stock clutch Sachs 2.5 will last 2x as long as especially if you plan on doing ANYTHING to the car. Although in my opinion the lwfw is waste...
Old Nov 10, 2016 | 06:47 AM
EdLebby's Avatar
the car is relatively new to me - b/c it goes to 1.2 bars, i know it must have had a flash done to the ecu (hope i am using the right jargon)
also, the exhaust is aftermarket
the car is an x50
perhaps with all of this a more robust clutch than stock is recommended?
would the 2.5 handle this setup?
thanks guys
Old Nov 10, 2016 | 07:53 AM
SpeedAddict's Avatar
SpeedAddict is a name known to allSpeedAddict is a name known to allSpeedAddict is a name known to allSpeedAddict is a name known to allSpeedAddict is a name known to allSpeedAddict is a name known to all
the car is an x50
thanks guys
Yes, the Sachs 2.5 will hold more power than the stock connecting rods will. Call markski above and he can get you the clutch. I just bought one from him as well.
Old Nov 10, 2016 | 10:54 AM
32krazy!'s Avatar
kevin from rennlist (ultimate motor works) has some good sales on the 2.5 if your staying in the street theres no need to run a lwfw but inspect the dual mass oem flywheel . if you see any hotspots or uneven wear get a new one. add another 800$ for the flywheel
Old Nov 10, 2016 | 11:33 AM
EdLebby's Avatar
thanks
Old Nov 10, 2016 | 01:12 PM
C1Forged's Avatar
LWFW depends heavily on what option you go for, and more times than not, the chatter comes from the disk, not the flywheel. I've had a number of them in previous cars, and I'm running one in my WRX, never experienced chatter of any kind until I ran a 6 puck.
I typically recommend the LWFW simply because it adds to performance, and when I do upgrades I try and go all out instead of replacing half of the assembly. Not to mention that if his clutch is slipping, he will either need a new flywheel, or have to get it resurfaced, since there will be glazing/hot spots on it.
In regards to OP from everyone else's advice, I would strongly encourage going with the Sachs 2.5 for the reasons stated above. Your stock clutch already slipped on you, no point in putting in another clutch that can/will do the same down the road.
