Silver bullet (v3)
Old Jan 18, 2017 | 08:32 AM
996tt550hp's Avatar
996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute
You don't know what's beyond the pistons once you pull the case apart. Crank could be scored with the rods
Old Jan 18, 2017 | 09:28 AM
flewis763's Avatar
flewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond repute
Originally Posted by brnrdtns
Looks good. Are you having Sean build it a day while you wait? If so I would clean all of the parts you can so he doesn't have to. That will save him a ton of work so it can get done on time. I would pull those cylinder housings too and pop out the cylinders. From there you can remove the pistons and rods easily as well. Pull the studs also. That would prob save a few hours of work so you can drive home with your engine.
no I'm having him ship it back
Old Jan 18, 2017 | 09:30 AM
flewis763's Avatar
possible but didn't sound like spun bearing. Dealt with tons of this on Subarus. Sounded more like a rods knock. It was a very light knock.
Old Jan 18, 2017 | 02:16 PM
pwdrhound's Avatar
Hope all is ok internally Freddy. In case you do have a damaged crank however, I have a mint condition low mileage one on hand.
Old Jan 18, 2017 | 08:16 PM
flewis763's Avatar
I really hope not but thanks for the offer john.
Old Jan 18, 2017 | 08:20 PM
flewis763's Avatar
I got one of the heads ported today amount all the other crap going on. Don't have the time I wish I did to make them perfect but they came out pretty well. Other one tomorrow. Really pushing to try and have everything done and be ready to leave Saturday morning.
Old Jan 19, 2017 | 10:19 AM
SeattleTurbo's Avatar
SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !
Freddy, while you've got everything all apart is there any way it would be convenient or easy for you to take a few pics of the engine wiring harness, I'm trying to trace where/if the wires providing 12v power to the ignition coils come together... No worries if that's not easy to access for you.
Old Jan 21, 2017 | 07:15 AM
flewis763's Avatar
All loaded up and ready to go...until I realised I had a bad front wheel bearing on the pickup last night. I well, on the way to Vegas today.
Old Jan 21, 2017 | 08:20 AM
brnrdtns's Avatar
brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !
Safe travels. You are in for like 40 hours of driving.
Old Jan 21, 2017 | 11:17 AM
flewis763's Avatar
closer to 60 by the time it's all said and done
Old Jan 21, 2017 | 04:07 PM
32krazy!'s Avatar
i dont see a toolbox back there!
Old Jan 26, 2017 | 10:24 PM
flewis763's Avatar
Well we found the issue
Old Jan 26, 2017 | 11:09 PM
996tt550hp's Avatar
How far are u going to build the car?
Old Jan 27, 2017 | 07:43 AM
flewis763's Avatar
well most of the car is pretty far along. As for now
motor
rods
pistons
iron sleeves
12mm studs
trans
997 gt2 rs main shaft 1-3 gear
steel syncros
billet side cover
going to push these little 20g to the max this season then upgrade turbos next winter
Old Jan 27, 2017 | 08:46 AM
996tt550hp's Avatar
What about injectors, rails, fpr, bigger fuel lines, TB, radiators, clutch, fuel pumps, tune, mafless, gt3 oil pump, grind cams.
Have SRM check on the porting job you did to make sure there in spec.
I would change out all bearings in trans, change out 4-6 gears to new brass syncros.
