Lower Control Arm from EPS
Old May 22, 2017 | 10:21 AM
porsche996tt_tpe's Avatar
porsche996tt_tpe is infamous around these parts
Hi
Car is 2002 996tt. Any one used these lower control arms from EPS on their 996tt? These fit the turbo model (I assume all 996 use the same arms)? And how are they?
http://www.ebay.com/itm/221785273709?ul_noapp=true
Thanks!
Old May 22, 2017 | 07:21 PM
r6vr6's Avatar
r6vr6 is a name known to allr6vr6 is a name known to allr6vr6 is a name known to allr6vr6 is a name known to allr6vr6 is a name known to allr6vr6 is a name known to all
If your looking for reasonably priced ones with the same joint as factory see elephant racing. I saw these too last year and from what most people said they are not a good idea. I could not find anyone they'll at actually had them though.
Old May 22, 2017 | 08:08 PM
993GT's Avatar
993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !993GT Is a GOD !
factory is a balljoint, zero deflection and 'zero' resistance to movement....the ones above using a bushing are a bad idea...
Old May 22, 2017 | 08:48 PM
OK! There are many non-TRW (factory) replacement. Are these of the original ball-joint design? Can they do the work? I previously had one of those non-OEM designs they seem to rattle a year or two later...
Thanks!
Old May 22, 2017 | 10:34 PM
pwdrhound's Avatar
Another case of people trying to reinvent the wheel only to end up with an inferior part... Buy the OEM stuff and be done with it. It's cheap and it works. End of story..
Old May 23, 2017 | 05:21 AM
stevemfr's Avatar
stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !stevemfr Is a GOD !
I stumbled across a video on YouTube by the manufacture of these arms a while back. They were actually trying to make the stiffness of the bushing a selling point. They were "loading" the suspension which was supposed to be good. What a load of....
These arms reduce performance and don't even offer a significant savings over what is a relatively inexpensive part to begin with. Utterly pointless.
Rental Metard
May 30, 2017 03:02 PM
