996tt header question
Old Jun 3, 2017 | 10:43 AM
acs370's Avatar
acs370 is infamous around these parts
Why is the other exhaust manifold welded on the flanges and the other not?
Noticed when grinded the welds smoother today. Should I tig-weld the flanges or not?
Old Jun 3, 2017 | 11:54 AM
Macster's Avatar
On my 2003 Turbo neither manifold has any welds present around the header tubes on either side.
Looks like someone welded that one side maybe because of leaks real or imagined.
Old Jun 3, 2017 | 12:03 PM
Stebo's Avatar
Stebo has a reputation beyond reputeStebo has a reputation beyond reputeStebo has a reputation beyond reputeStebo has a reputation beyond reputeStebo has a reputation beyond reputeStebo has a reputation beyond reputeStebo has a reputation beyond reputeStebo has a reputation beyond reputeStebo has a reputation beyond reputeStebo has a reputation beyond reputeStebo has a reputation beyond repute
Mine aren't welded either
Old Jun 3, 2017 | 12:17 PM
brnrdtns's Avatar
brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !
Someone welded it.
Old Jun 3, 2017 | 12:21 PM
Jferrante's Avatar
Jferrante has a brilliant futureJferrante has a brilliant futureJferrante has a brilliant futureJferrante has a brilliant futureJferrante has a brilliant futureJferrante has a brilliant futureJferrante has a brilliant futureJferrante has a brilliant futureJferrante has a brilliant futureJferrante has a brilliant futureJferrante has a brilliant future
Yup someone welded it. I had leaks from mine and thats where it was welded
Old Jun 3, 2017 | 01:12 PM
bushrat's Avatar
bushrat has a reputation beyond reputebushrat has a reputation beyond reputebushrat has a reputation beyond reputebushrat has a reputation beyond reputebushrat has a reputation beyond reputebushrat has a reputation beyond reputebushrat has a reputation beyond reputebushrat has a reputation beyond reputebushrat has a reputation beyond reputebushrat has a reputation beyond reputebushrat has a reputation beyond repute
Does not look like a factory weld
Old Jun 3, 2017 | 08:07 PM
acs370's Avatar
Thanks guys!, I will weld the other as well then.
Old Jun 4, 2017 | 04:00 PM
Macster's Avatar
If the other side isn't leaking you might want to leave it alone. If the welding doesn't go well the manifold can warp/deform and the exhaust may leak as a result.
Old Jun 4, 2017 | 04:19 PM
bushrat's Avatar
+1 if it aint broke...don't fix it
Old Jun 6, 2017 | 09:58 AM
s65e90's Avatar
s65e90 is infamous around these parts
I would do it on a jig. Make a panel and bolt the header to it so when you weld it won't deform and stay true.
Old Jun 7, 2017 | 05:38 PM
ExclusiveTT's Avatar
ExclusiveTT has a reputation beyond reputeExclusiveTT has a reputation beyond reputeExclusiveTT has a reputation beyond reputeExclusiveTT has a reputation beyond reputeExclusiveTT has a reputation beyond reputeExclusiveTT has a reputation beyond reputeExclusiveTT has a reputation beyond reputeExclusiveTT has a reputation beyond reputeExclusiveTT has a reputation beyond reputeExclusiveTT has a reputation beyond reputeExclusiveTT has a reputation beyond repute
sidebar, do any of the aftermarket headers produce a gain over stock headers?
Old Jun 7, 2017 | 08:50 PM
Jferrante's Avatar
I have read numerous places no unless you are getting crazy 850+ HP
