DIY Injector Replacement Guide (Engine In) ??????
Old Jul 3, 2017 | 11:39 AM
Jeanmarcboilard's Avatar
Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !Jeanmarcboilard Is a GOD !
Here's another diagram
Old Jul 3, 2017 | 11:46 AM
gclasse's Avatar
gclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond repute
exactly!
Jferrante's Avatar
Jferrante has a brilliant futureJferrante has a brilliant futureJferrante has a brilliant futureJferrante has a brilliant futureJferrante has a brilliant futureJferrante has a brilliant futureJferrante has a brilliant futureJferrante has a brilliant futureJferrante has a brilliant futureJferrante has a brilliant futureJferrante has a brilliant future
Ok - well I think I figured out the problem - my secondary air pump was removed so I don't believe I have the 4 way fitting anymore. Here is a pic of everything out of the way and where we should be able to see the 4 way connection.
Old Jul 3, 2017 | 11:54 AM
Jferrante's Avatar
nevermind that goes on the FPR at the rail....back to square 1
Old Jul 3, 2017 | 12:01 PM
gclasse's Avatar
just make sure that these points are connected or plugged (capped off) connect to one of them and you should be OK
Old Jul 3, 2017 | 12:04 PM
I'm not sure of the configuration without your secondary air pump. I know some guys here have removed them, maybe they chime in on their set up.
Old Jul 3, 2017 | 12:06 PM
Jferrante's Avatar
Yea I believe if they are simply plugged I should be ok - these are simply vacuum lines running to FPR, throttle body and secondary air. If i have the first 2 the third just needs to be plugged since that is no longer running. I forget how this was routed when it was deleted....will report back when the car is running (or not)
Old Jul 7, 2017 | 05:20 PM
mrthree's Avatar
mrthree is a glorious beacon of lightmrthree is a glorious beacon of lightmrthree is a glorious beacon of lightmrthree is a glorious beacon of lightmrthree is a glorious beacon of lightmrthree is a glorious beacon of light
Jferrante, thinking about deleting the secondary air pump on my car. Any wisdom on what you see as far as blocking / rerouting of lines is appreciated. Thanks man!
Alex
