Car is shifting a lot smoother now.
Old Jan 22, 2006 | 07:25 PM
RT7's Avatar
RT7
Show-N-Go like J-Lo Mofo
RT7 is infamous around these parts
I had my transmission fluid replaced the other day by MindOverMotorsports (thanks Brad), the car shifts a lot better now. Initially, it was a bit rough when downshifting from 3rd to 2nd, but now it's not happening anymore.
Old Jan 22, 2006 | 10:05 PM
AlanS's Avatar
AlanS is infamous around these parts
Which Fluid?
Which fluid did you use?
Old Jan 23, 2006 | 05:33 AM
kiko's Avatar
kiko is infamous around these parts
Please tell us which fluid you use, many of us have the same issue.
Old Jan 23, 2006 | 04:51 PM
Tim W.'s Avatar
Tim W. is infamous around these parts
Guys:
Is there a DIY for the tranny fluid?
Tim
Old Jan 23, 2006 | 05:26 PM
Ruiner's Avatar
I know that BG makes a good tranny fluid, BG Syncroshift. I used it in my 3000GT VR-4 with a Getrag tranny many years ago. It did wonders for the tranny. Redline MTL is good as well, but there are rumors that it accelerates syncro wear. Read the whitepapers on their site and make your own decision.
Old Jan 23, 2006 | 07:00 PM
RT7's Avatar
RT7
It's OEM fluid. There's DIY at www.renntech.org. You need a pump to push the fluid, it's a time consuming process.
Old Jan 23, 2006 | 09:21 PM
djantlive's Avatar
What was your mileage?
Old Jan 23, 2006 | 09:51 PM
RT7's Avatar
RT7
Almost 33k
Old Nov 6, 2015 | 06:21 PM
Mish_Mish's Avatar
Mish_Mish has much to be proud ofMish_Mish has much to be proud ofMish_Mish has much to be proud ofMish_Mish has much to be proud ofMish_Mish has much to be proud ofMish_Mish has much to be proud ofMish_Mish has much to be proud ofMish_Mish has much to be proud of
I just changed Amsoil 75W90 to Redline MTL and difference is noticeable. Gears just fall in perfectly, even my notchy second gear is perfectly pleasant now.
I do not know how Redline is supposed to wear synchronizers faster, if it obviously provides better lubrication.
Old Nov 6, 2015 | 08:31 PM
jpflip's Avatar
Originally Posted by Tim W.
Guys:
Tim
I've made one on Renntech but you have to be a contributing member....
http://www.renntech.org/forums/tutor...l-replacement/
Old Nov 7, 2015 | 09:42 AM
Macster's Avatar
Not sure you can assume better lubrication.
One is dealing with physics when shifting. These engines produce a lot of torque and as a result the transmission components have to be built to withstand this. Among other things this means the components are heavier. It takes time for the synchros to spin up the slower gear set so the shifting can take place without the crunching.
The faster shifting can be the Red Line fluid provides less lubrication and the synchronizers thus spin up quicker and thus experience more wear.
Old Nov 7, 2015 | 09:51 AM
jason952's Avatar
jason952 is infamous around these parts
About to switch from the factory fill (2003 car with 28k) to motul 300...its specs are very much the same as delvac
adnanm3
Oct 25, 2016 08:38 AM
PorscheEnthusiast
Nov 13, 2015 02:23 PM
trek737
Aug 23, 2015 08:12 AM
trek737
Aug 20, 2015 04:40 PM
MAcarbon
Aug 19, 2015 04:52 PM
