Boost Leak Question
Old Jul 25, 2017 | 05:18 PM
Jferrante's Avatar
Jferrante has a brilliant futureJferrante has a brilliant futureJferrante has a brilliant futureJferrante has a brilliant futureJferrante has a brilliant futureJferrante has a brilliant futureJferrante has a brilliant futureJferrante has a brilliant futureJferrante has a brilliant futureJferrante has a brilliant futureJferrante has a brilliant future
Boost Leak Question
So I noticed I was only getting about half boost at the track this weekend and have traced it down to where the F-Hose connects to the aluminum intake (see below) - when I try to pressurize the system it comes directly out of that hole connected to F hose.
Since I just had the diverters out I am guessing one of the check valves is bad? Any other ideas? Thinking #45 and #21 in the diagram
Old Jul 25, 2017 | 05:47 PM
nbressette's Avatar
nbressette has much to be proud ofnbressette has much to be proud ofnbressette has much to be proud ofnbressette has much to be proud ofnbressette has much to be proud ofnbressette has much to be proud ofnbressette has much to be proud ofnbressette has much to be proud ofnbressette has much to be proud ofnbressette has much to be proud of
Could be bad DVs but I would bet its a bad #16 check valve. Try taking off the hose that connects right before the inlet side of the driver side turbo, that's where a bad #16 would dump out I think. When mine when it pushed air back up the intake tract and so it seemed like it was coming out by the F hose but it wasn't.
Old Jul 25, 2017 | 05:50 PM
Jferrante's Avatar
I can feel the air coming out of the intake in the picture so it is something in the diverter valve region....that's why I thought it was 45 or 21. I don't have secondary air anymore so I wonder if 16 is still even in the car.
Old Jul 25, 2017 | 06:14 PM
'02996ttx50's Avatar
a cracked #16 wouldn't limit boost to "half". larger leak/hose etc, is my guess. plus, you'd hear it "whistle" as air escaped while pressure testing.
Old Jul 25, 2017 | 06:30 PM
Jferrante's Avatar
Yea the air is coming through the intake that hooks up to the F hose...its all coming out from there...
Old Jul 25, 2017 | 07:36 PM
which again suggests it's lower by the y pipe or direct from the turbos, and not atop the plenum where the 16 is. i have no direct experience with the forge or any aftermarket hose but i'd be looking there. i'd say check the inlets at the turbos, but i'm supposing you already have?
this is ( presumably ) a *large* leak. "minor" leaks ( as you know ) don't cut boost by half or result in "limp mode". i'll bet ya, it's a hose.. what else could it be? last major boost loss i had was a c-clip failed. trace the hose(s) from the inlets to the y-pipe(?).
all i got. GL.
Old Jul 25, 2017 | 07:45 PM
Jferrante's Avatar
all i got. GL.
Thanks - maybe I am not being clear - the "leak" is clearly coming from the inlet where the F pipe meets the aluminum intake housing...not anywhere else. So I was curious if this is the result of a stuck open check valve around the DV's since that is where the air is coming in
Old Jul 25, 2017 | 07:55 PM
you were clear. my issues were always related to "lower" along the intake path, hence my bias toward that region. what do you mean when you say you just had the dv's "out"?
whatever was last messed with.. (?)
Old Jul 25, 2017 | 08:08 PM
Jferrante's Avatar
gotcha. I just had my injectors cleaned so everything was out. I will double check the flow on the check valve tomorrow see if it's upside down or something stupid like that. if not i am stumped
Old Jul 25, 2017 | 08:25 PM
got it. that then leads even more credence to the supposition that "last thing messed with" will lead you to your leak, as opposed to a "failed" part. again, GL w it.
Old Jul 26, 2017 | 07:49 AM
Jferrante's Avatar
Yup - checked this morning - going to throw some 710n DVs in and see if those are the culprit and work from there.
Old Jul 26, 2017 | 09:21 AM
my previous car had the older oem's, then i "upgraded" to the 710n's. with this car, when i got it, it already had evoms installed, i have never again had a dv issue. they seem to be indestructible and have never "honked" once lol. again, gl with it!
