996 Turbo with 997 Gt2 Transmission hard
Hi every one..
I change my transmission to 997gt2 with clutch and master slave without gt2 assistant spring
The clutch is tooooo stiff and not return quickly??!
look at youtube:
[U
any help
Mohd
Q8
look at youtube:
[U
any help
Mohd
Q8
I think something problem with hydraulic system because now without Accumulator!!!
Porsche Gave me Hydrolic porsche oil?! is it diffirenet oil between gt2 and turbo clutch oil?!
Sounds like Porsche hosed you if they gave you "hydronic oil" which is what Pentosin is.
Did you mean Gt2 convertion evoms conversion??
I change all transmission to Gt2 997 tranny!
but they gave me this oil:
Like I said earlier. Porsche screwed you. Unfortunately that is Pentosin in Porsche packaging. Same exect stuff as S11. You will need to change out your slave, master, etc as that stuff ate the seals.. Sorry...
In 996tt The clutch slave cylinder is hooked up to the steering pump, right?!
The 997 gt2 maybe nothing ... Should I block something?!
I changed the clutch master only
it is stiff but working good
I will order assistant spring now ..not available in porsche store
