996TT Wheel Offset Question
Old Dec 11, 2017 | 09:25 PM
ritchrwi's Avatar
ritchrwi is infamous around these parts
I have an awd 996TT. I curently have 997 wheels on my car and its lowered:
19 x 8.5”- 56 offset-
pilotsports 235/35/19
19 x 11”-67 offset
pilotsports 305/30/19
My question can these wheels fit???
Renned Concave rims
19 x 9.5”- 35 offset
19 x 12”- 38 offset
Thanks in advance
Old Dec 12, 2017 | 10:41 AM
Apex Factor's Avatar
Apex Factor is a jewel in the roughApex Factor is a jewel in the roughApex Factor is a jewel in the rough
19 x 11”-67 offset
Renned Concave rims
19 x 12”- 38 offset
Thanks in advance
I'm going to say no on the front. The rears will be fine.
The front will stick out 1.3 inches farther from your current setup. If you look straight down at your wheel in the front and if there is 1.3 inches of room then yes it will work.
The rear will work because I'm running a similar spec. But if you want to know, the rear will stick out 1.6 inches farther out from your current setup.
Hope this helps.
Old Dec 12, 2017 | 11:29 AM
ritchrwi's Avatar
Thanks for the information it was very helpful, since my car is lowered i could get away with a 3mm in the front and 5mm in the back possibly but 1.3" will not work...
thanks again
M5_Forever
Nov 15, 2012 09:39 AM
nevert00fast
Wheels/Tires
May 22, 2012 10:57 AM
ExclusiveTT
Wheels/Tires
20
Aug 31, 2009 04:37 PM
