Radar detector in the Center Rear view Miror
Subscribe
Feb 15, 2006 | 08:21 AM
Hi,
A while back ago, i saw a radar detector display integrated into the center rear view miror of a 996 car. I think it was valentine1. Did someone has more informations about it ?
Reply
Feb 15, 2006 | 09:50 AM
Someone please post information about this. Is it an easy install? How about a group buy??
Reply
Feb 15, 2006 | 11:26 AM
Here is the web site were they can be bought from: http://www.aidesign.com/shop/index.p...products_id=23
I have read that they have caught on fire Does anyone have more information about this problem
Reply
Feb 15, 2006 | 11:37 AM
Wow... that is pretty expensive...
Reply
Feb 15, 2006 | 12:54 PM
Its a super easy install.
You actually put the detector inside the rear dech lid. When you pull of the decklid.......you cut the foam out and stick the V1 in there. Then you just run the wire to the center counsil. You tap in on the power wire...I forget the exact one, then just run the wire up behind the panel that your leg hits while you drive....then under the steerind wheel(still behind the panel)...make sure you zip tie it in there.... then up the inside of the pillar...across the headliner....then into the mirror housing. Should only take an hour....if you know how to take out the center counsil....the one where the e brake and shifter are.
It works real good. I had it in mine, also, I had the same set up in my M5, but the dtector was in the front of the headliner with No obstructions......the V1 in the Porsche worked the exact same. Exept, you lose the laser function.
Reply
Feb 15, 2006 | 05:10 PM
Hi,
Isn't the rear deck lid pretty far away from the windshield ? Also, the two seats are probably blocking most of the radar beam...
Reply
Feb 15, 2006 | 06:01 PM
I Have That Mirrior Display, It Never Caught On Fire.
Reply
Feb 15, 2006 | 07:54 PM
It works. You don't have to have an un-obstructed view for radar. It pretty much goes through everything. It worked 100% in my car.
Reply
Feb 15, 2006 | 08:00 PM
That's sweet I want one. Sounds more complicated with manual dim mirror.
Reply
Feb 15, 2006 | 08:29 PM
Quote: It works. You don't have to have an un-obstructed view for radar. It pretty much goes through everything. It worked 100% in my car.
just to be sure, you are saying that you put the detector right under the rear backglass ?
Reply
Feb 15, 2006 | 08:35 PM
can get intergrated fron and rear. beltronics for 759.00 with blocker 900.00 works great
Reply
Feb 15, 2006 | 08:38 PM
beltronics has a rear above lic fram mount . and two units behind grill really works well saved my........... bunches of times
Reply
Feb 15, 2006 | 08:48 PM
I have K40 360 surround protection, completely invisible with laser defuser, simply due to the discreet installation. Nothing visible in the car until it lights up.
Reply
Feb 15, 2006 | 08:53 PM
Quote: can get intergrated fron and rear. beltronics for 759.00 with blocker 900.00 works great
Why does it sells for 499$ on belltronics site ?
Reply
Feb 15, 2006 | 09:57 PM
Quote: just to be sure, you are saying that you put the detector right under the rear backglass ?
You take out the rear deck lid.....its the one that says "turbo" on it. Its the one you remove to get to the Computer......Then just cut out the foam. It sits right in there.
Reply
