Wheel question for DE events
Old Jan 16, 2019 | 06:57 AM
trillypop's Avatar
trillypop is infamous around these parts
Originally Posted by jayzbird
Note with 315s on the rear I got rubbing on the inner fender liners (not in the garage, but on the track). 5mm spacers solved the issue. This with stock turbo twists.
This is true. My inner fender liner had a bit of wear on the rear lower corner from the track setup, so I just heated it up and bent it as close to the charge pipe silicone coupler as possible, and now it doesn't rub even without spacer.
For street wheels I run a 12" wide wheel with a 315/30/18 and there is no rubbing inner or outer fender liner.
cooperlee
NY Tri State
Jun 7, 2010 03:10 PM
teutonictrio
May 6, 2004 06:04 AM
20C4S
Dec 8, 2003 04:11 PM
orlando_deke
Dec 2, 2003 08:05 PM
