Stub Axles for RDW Conversion
Old Jul 4, 2019 | 11:12 PM
nick49's Avatar
nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !
I bought a couple of used axles from a dismantler salvage yard, one good, the other damaged. I got them cheap, disassembled them to get what I needed, saved my originals to go back to AWD when and if I ever decide to sell the car.
Old Jul 5, 2019 | 02:08 AM
ghostofpain's Avatar
ghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to behold
Wise plan...
Old Jul 24, 2019 | 12:02 PM
OK51MON's Avatar
OK51MON is infamous around these parts
Do you actually need these axles for RWD conversion?
I thought you just pull out the front driveshaft and viscous coupling and you're done?
What am I missing?
Perhaps its different for a tiptronic
Old Jul 24, 2019 | 02:15 PM
Third-Reef's Avatar
Third-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond repute
RWD just means disconnecting the drive shaft to the front differential. A proper RWD conversion removes the front differential and axles and removes aprox 100 Lb?
Old Jul 25, 2019 | 05:05 PM
vogz's Avatar
vogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond repute
What am I missing?
To elaborate on this. The front axles have ABS sensor rings on the outer axle stub that tell the ABS sensor how fast the wheel is spinning or if it stops, etc. If you just remove the axles, you'll throw and ABS light and lose ABS function and probably PSM function too. Re-installing the stub sans the bar, and inner CV or buying fabbed axle stubs allow you remove most of the axles and the front diff/viscous coupling for full weight and parasitic drag benefit of RWD conversion.
usasoccerfan1972
Nov 17, 2014 05:43 PM
pwdrhound
Sep 25, 2013 02:11 PM
REVS11
Jan 28, 2011 03:42 PM
REVS11
Jan 16, 2011 08:29 PM
