Ideas to easily open the frunk when you have disconnected the battery?
Old Jan 12, 2020 | 08:43 PM
Gunther's Avatar
Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !
I'm considering displaying my Turbo at a car show and one of the requirements is to disconnect the battery and lock the car. Any ideas on how to then easily open the frunk to reconnect the battery? I have had to remove the from bumper in the past and don't want that level of hassle to display my car. Yes, I know about the wire behind the light.
Any other ideas would be appreciated.
Old Jan 13, 2020 | 03:45 AM
pancing's Avatar
pancing has a spectacular aura aboutpancing has a spectacular aura aboutpancing has a spectacular aura about
Buy a lithium jump starter and use it to power the locks from the driver side console.
Old Jan 13, 2020 | 05:29 AM
Gunther's Avatar
I have one. Now I need to test it out.
Can you be more specific about where to jump from?
Old Jan 13, 2020 | 08:09 AM
wross996TT's Avatar
Old Jan 13, 2020 | 08:33 AM
brnrdtns's Avatar
brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !
If you've never had to figure out how to open the front the "hard way" you are a fortunate guy!
Old Jan 13, 2020 | 09:43 AM
pancing's Avatar
"Leave the key in the door lock" make sure you follow that.
Old Jan 13, 2020 | 04:05 PM
'02996ttx50's Avatar
re-routing the wire so it lays flush into the headlamp enclosure remaining unseen until you fetch it out with a needlenose plier ( when necessary ) seems the most obvious and expedient solution. it takes all of 3 seconds to pull it and voila. open frunk. but you knew that lol
Old Jan 15, 2020 | 11:51 PM
spiderman's Avatar
spiderman is a splendid one to beholdspiderman is a splendid one to beholdspiderman is a splendid one to beholdspiderman is a splendid one to beholdspiderman is a splendid one to beholdspiderman is a splendid one to beholdspiderman is a splendid one to behold
Attach something to the eye on the end of the cable that hangs down somewhere you can easily access it?
I managed to pull the cable with the right tire in place once (lug nut key was in tool kit in frunk). It was a pain in the rear but it worked.
Old Jan 16, 2020 | 06:30 AM
eds996tt's Avatar
eds996tt is a glorious beacon of lighteds996tt is a glorious beacon of lighteds996tt is a glorious beacon of lighteds996tt is a glorious beacon of lighteds996tt is a glorious beacon of light
i use a battery tender to power the car with battery disconnected. always firmly connected to the cables never a concern
Old Jan 17, 2020 | 07:05 PM
Gunther's Avatar
Thanks for all the comments. I have to remove the battery and lock the car while my car is being displayed at the Washington D.C. car show.
Old Jan 20, 2020 | 09:25 PM
jayzbird's Avatar
jayzbird is a splendid one to beholdjayzbird is a splendid one to beholdjayzbird is a splendid one to beholdjayzbird is a splendid one to beholdjayzbird is a splendid one to beholdjayzbird is a splendid one to beholdjayzbird is a splendid one to beholdjayzbird is a splendid one to behold
Thanks for all the comments. I have to remove the battery and lock the car while my car is being displayed at the Washington D.C. International car show.
I routed my cable to go behind the front side marker light, which is easy to pop out. Had to crimp on another 18” or so of cable.
Old Apr 16, 2020 | 09:22 PM
lconn's Avatar
lconn is infamous around these parts
I carry a small battery and alligator clips in my glovebox. I've had the battery die before and have been able to open it using a 9v radio battery, alligator clips and the pullout widget in the fuse panel. I would recommend a 12v battery, the 9v can be finicky (but it was in my drawer). This way you can always get the frunk open.
Old Apr 17, 2020 | 04:22 PM
a 9v eh? never heard that before..good tip.
Wildcat1212
Jul 24, 2024 06:23 PM
minming
Dec 21, 2017 10:29 AM
tomb18
Jun 4, 2015 03:11 PM
dan_189
May 11, 2015 01:34 AM
Stroker
Dec 17, 2014 09:01 AM
