Brake question
Old Mar 9, 2020 | 07:24 PM
jdexter's Avatar
jdexter is a splendid one to beholdjdexter is a splendid one to beholdjdexter is a splendid one to beholdjdexter is a splendid one to beholdjdexter is a splendid one to beholdjdexter is a splendid one to beholdjdexter is a splendid one to behold
Brake question
What's up with this. New rotors got a little surface rust. Next time out it came off, but looks like the pads don't contact as much as I'd expect. Any opinions on this? Click image for larger version
Old Mar 9, 2020 | 10:21 PM
nick49's Avatar
nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !nick49 Is a GOD !
New pads too?
May take some time to bed them in. They should contact 100% and you should have a clean sharp line when that happens.
Old Mar 10, 2020 | 05:07 AM
jdexter's Avatar
I have street and track pads, none are new. Both are at almost full thickness since I barely need the brakes on the street and the track pads are almost new...
Old Mar 10, 2020 | 03:25 PM
Third-Reef's Avatar
Third-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond reputeThird-Reef has a reputation beyond repute
I put new pads on used 350 rotors and it took 1K plus miles before the contact was all the way across. This was on my 6 pot Brembo gt BBK.
Old Mar 10, 2020 | 03:55 PM
pancing's Avatar
pancing has a spectacular aura aboutpancing has a spectacular aura aboutpancing has a spectacular aura about
Originally Posted by jdexter
What's up with this. New rotors got a little surface rust. Next time out it came off, but looks like the pads don't contact as much as I'd expect. Any opinions on this? Attachment 534113
Happened to me in my old vette when i swapped rotors and kept pads. Went away after pads wore down. How did you even get that much rust?
Old Mar 10, 2020 | 04:19 PM
jdexter's Avatar
I had to grab some gas after they salted the roads back in November. I washed the car, but it still caused some surface rust...
Old Mar 10, 2020 | 05:07 PM
pancing's Avatar
Ah okay, well just drive it or you can sand your pads down.
Old Mar 16, 2020 | 07:19 PM
Twinturbofan's Avatar
Twinturbofan has much to be proud ofTwinturbofan has much to be proud ofTwinturbofan has much to be proud ofTwinturbofan has much to be proud ofTwinturbofan has much to be proud ofTwinturbofan has much to be proud ofTwinturbofan has much to be proud ofTwinturbofan has much to be proud ofTwinturbofan has much to be proud ofTwinturbofan has much to be proud of
You can speed it up by laying a piece of glass on your workbench and tape a sheet of 100-200 grit sandpaper face up on it. Take your pads face down on the sandpaper and rub them around in a figure 8 pattern with moderate preassure. The glass is to assure a completely flat surface. Then reinstall.
Old Mar 16, 2020 | 07:35 PM
pancing's Avatar
Lol i never thought about that, i just used the concrete floor to get glazing off lol.
Old Mar 23, 2020 | 08:13 PM
motogman's Avatar
motogman is infamous around these parts
Wow - that looks like more than a little surface rust... but hard to tell. Could also consider having the rotors resurfaced as well as other pad suggestions.
Old Mar 24, 2020 | 06:44 AM
kamlung's Avatar
5 Year Member
kamlung is a name known to allkamlung is a name known to allkamlung is a name known to allkamlung is a name known to allkamlung is a name known to allkamlung is a name known to all
i've never found a shop that turns slotted rotors
Old Mar 24, 2020 | 09:31 PM
kdm's Avatar
kdm
5 Year Member
kdm is a glorious beacon of lightkdm is a glorious beacon of lightkdm is a glorious beacon of lightkdm is a glorious beacon of lightkdm is a glorious beacon of light
I had the front slotted rotors on my Aston Martin turned by a local machine shop. They can't use the normal tools due to slots, so used some type of grinding stone. I didn't actually see them do the work.
Had them measure and record the final thickness for each rotor to ensure they were well over minimum specs.
Turned out well. Did leave a cross hatch pattern that resulted in slight wirring noise for a couple thousand miles until it got worn down.
brockster
Feb 4, 2017 09:14 PM
North Shore 911
May 6, 2015 08:17 PM
scatkins
Dec 28, 2014 03:01 AM
rrrruben
Feb 14, 2014 12:32 PM
landjet
May 14, 2011 01:12 PM
