TT and GT2 Top Speeds
Old Mar 5, 2006 | 07:58 AM
lee lovell's Avatar
lee lovell is infamous around these parts
What makes the GT2 have a slightly better top end speed?
Is it different size tyres, higher rev limit, gearing, or something else.
Just wondered if i will have to have my rev limiter raised to achieve a true 200Mph or it can be achieved through different sized tyres.
For any GT2 owners the rev limiter on the tt cuts in at 6750rpm.
Cheers.
Old Mar 5, 2006 | 10:59 AM
Ruiner's Avatar
Basic answer: more horspower and RWD (less driveline loss)
Old Mar 5, 2006 | 11:17 AM
Joe Weinstein's Avatar
yep. simply more power to the wheels. At top speed the primary
consideration is wind-resistence, which is quite close between
the two cars, so power will decide. Lowering the wind resistence
just a little might tip the balance with either car. I recall an old
article from the 60's (!) where it was claimed that adding a rectangle
of metal to the roof of a Jaguar XKE, the size of a license plate
lowered it's top speed by 10MPH...
Joe
Old Mar 5, 2006 | 11:22 AM
lee lovell's Avatar
I was of the understanding that the tt's top speed was limited by the rev limiter. Ive upgraded to a stage 4 but i still hit the rev limit at the same rpm so my top speed will be the same.
The tt has a lower drag co than the GT2 so has less wind resistance.
Old Mar 5, 2006 | 11:24 AM
Ruiner's Avatar
Doesn't the (stock) rev limiter hit at around 196-198mph in 6th gear?
Old Mar 5, 2006 | 03:45 PM
WyattH's Avatar
WyattH Is a GOD !WyattH Is a GOD !WyattH Is a GOD !WyattH Is a GOD !WyattH Is a GOD !WyattH Is a GOD !WyattH Is a GOD !WyattH Is a GOD !WyattH Is a GOD !WyattH Is a GOD !WyattH Is a GOD !
If you are hitting the rev limiter in 6th gear, more power will not help you (other than getting there faster). I wouldnt suggest removing the rev limiter. Youll either need to get a higher final gear (lower #, right?) to make each gear longer, or you will need bigger tires (wouldn't recommend this either).
I don't own a Porsche, so I can't say what the 6th gear redline is at. :thumbsup:
Old Mar 5, 2006 | 04:39 PM
iLLM3's Avatar
But also some tuners offer a higher redline, i know my car at stg 2 redlines at 7k!!
Old Mar 5, 2006 | 04:45 PM
Divexxtreme's Avatar
Yep. Mine's over 7k as well.
Old Mar 5, 2006 | 08:05 PM
WyattH's Avatar
I didn't mean to imply the engine couldnt rev more, I just ment I wouldnt remove the rev-limiter and go above the stock redline without further prep or tuning.
Murf4
New Member Introductions
Sep 3, 2015 10:10 AM
orbelo
Aug 30, 2015 12:26 PM
Fabspeed Motorsport
Aug 26, 2015 11:15 AM
Fabspeed Motorsport
Aug 18, 2015 03:24 PM
You have already rated this thread Rating: Thread Rating: 1 votes, 1.00 average.
