Sun-burned cluster replaced with a non-turbo cluster......
I know this may not working since I didnt find a turbo cluster locally, and I replaced a 04 Carrera cluster, everything is working fine and there is seat belt beep which I never have before......But then I found there is none turbo "Bar" to select to show
, there is nothing I can do right?
Probably not. If you are interested in a Turbo cluster, I have my stock one with black dials available. Works perfectly, I replaced it with an OEM white dial one. Willing to let it go for pretty cheap. Hit me up if you're interested.
Bcos of local, good condition and low price lol, cannot Imagine the turbo gauge is a cluster specific...
Ask someone with Durametric Pro to try to enable boost gauge. It might be possible, at least the selection to click is there.
Bigger problem is that you are not able to check oil level and your fuel gauge is off.
Well, if the cluster us from a C4, then the fuel fauge just needs calibration (with PIWIS) to be reliable. If it's from a C2, then it'll be off the scale. turbo and C4 have saddle shaped tank and fuel level metering below 20something liters is based on Motronic's calculation. C2 has a flat bottom tank and fuel gauge correlates directly to fuel level in tank.
Seems I should plug its lcd and swap to my original cluster is the right way for now...
I removed the factory Nav from my car and there is nothing about Nav in my cluster. It may be as simple as disconnecting it.
I removed mine also. But in the same center lower toggle screen with the boost gauge, I have a nav menu as an option. It shows "NAV --" or something like that. I'd love to disable that and not even show it as on the menu
Weird - I have nothing - mine is 2001.
