I ordered a track pad from Project mu and found there is cutting different from the diagram, but the diameter and model are all correct, would it fit in at all?
Had some research, seems to be its for the brake pad sensor...
No... The sensor plug is a hole in the edge of the brake pad backing that drops in from the top and runs parallel to the pad surface. The yellow arrow points to the hole.
